CUCME Not Incoming Calls, Outgoing calls ok
Hello everybody,
i am configuring a CUCME with SIP trunk, i can make calls to outside but i can´t recieve any from outside, this is my second time a configure with SIP
i´ve used the command debug voice dialpeer all to check was going on, but i can´t find the problem.
this is my config:
ip host sip-server A.B.C.D
voice service voip
ip address trusted list
  ipv4 A.B.C.D 255.255.255.252
  voice translation-rule 1
rule 1 /325277\(\)/ /1\1/
voice translation-profile IN
translate called 1
dial-peer voice 1 voip
description **Incoming Call from SIP Trunk**
translation-profile incoming IN
session protocol sipv2
session target sip-server
incoming called-number .
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
ephone-dn  1
number 100
description RECEPTION
ephone  2
mac-address AAAA.BBBB.CCCC
ephone-template 1
type 7942
keep-conference
button  1:1
NOTE: IP Address are hidden, just for security
These are the output of my debug/tests:
#test voice translation-rule 1 32527700
Matched with rule 1
Original number: 32527700       Translated number: 100
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
*Jan 29 16:17:14: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=32527700, Called Number=32527700, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=32527700
*Jan 29 16:17:14: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=32527700, Expanded String=32527700, Calling Number=32527700T
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
*Jan 29 16:17:14: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=32527700, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
*Jan 29 16:17:14: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
*Jan 29 16:17:14: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=59513212, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Match Rule=DP_MATCH_ANSWER; Calling Number=59513212
*Jan 29 16:17:14: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
   Dial String=, Expanded String=, Calling Number=59513212T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
*Jan 29 16:17:14: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6076
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=59513212
   Result=-1
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
*Jan 29 16:17:14: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704
*Jan 29 16:17:14: //-1/F0EA1F0180EB/DPM/dpAssociateIncomingPeerCore:
   Calling Number=59513212, Called Number=32527700, Voice-Interface=0x0,
   Match Rule=DP_MATCH_VIA_URI; URI=sip:A.B.C.D:5060
*Jan 29 16:17:14: //-1/F0EA1F0180EB/DPM/dpMatchPeertype:
*Jan 29 16:17:14: //-1/F0EA1F0180EB/DPM/dpMatchCore:
   Result=-1
*Jan 29 16:17:14: //-1/F0EA1F0180EB/DPM/dpMatchPeertype:exit@6076
   Match Rule=DP_MATCH_REQUEST_URI; URI=sip:32527700@E.F.G.H:5060;user=phone
   Result=-1
   Match Rule=DP_MATCH_TO_URI; URI=sip:32527700@I.J.K.L;user=phone
   Result=-1
   Match Rule=DP_MATCH_FROM_URI; URI=sip:59513212@X.Y.Z.Z;user=phone
   Result=-1
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=32527700
*Jan 29 16:17:14: //-1/F0EA1F0180EB/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1 Is Matched
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
*Jan 29 16:17:14: //-1/F0EA1F0180EB/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Jan 29 16:17:14: //-1/F0EA1F0180EB/DPM/dpAssociateIncomingPeerSPI:exit@6655
Can Anyone help me???
Thanks in Advance!!!
1 ACCEPTED SOLUTION
I looked on the other call leg of the SIP messages , here is the fault for call where Incoming is getting failed due to session timer is too small recieved from the SBC (provider)
Call ID:
Call-ID: SBC9722bb53005161bf8cca630444260574@SoftX3000
INVITE RECEIEVED FROM SBC--SIP
*Jan 29 16:53:19: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:32527700@(WAN):5060;user=phone SIP/2.0
Via: SIP/2.0/UDP (SIP_SERVER):5060;branch=z9hG4bK776928550196f0d843ca0b092
To: <32527700>
CSeq: 1 INVITE
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Max-Forwards: 70
Supported: 100rel,timer
User-Agent: Huawei SoftX3000 V300R601
Session-Expires: 300
Min-SE: 90
Contact: <59513212>
Content-Length: 376
Content-Type: application/sdp
v=0
o=HuaweiSoftX3000 4507886 4507886 IN IP4 (SIP_SERVER)
s=Sip Call
c=IN IP4 (SIP_SERVER)
t=0 0
m=audio 11554 RTP/AVP 8 0 18 4 2 98 98 98
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=rtpmap:4 G723/8000
a=rtpmap:2 G726-32/8000
a=rtpmap:98 G726-40/8000
a=rtpmap:98 G726-32/8000
a=rtpmap:98 G726-24/8000
a=ptime:20
a=fmtp:18 annexb=no
In response CME SENDs 422 response
Sent:
SIP/2.0 422 Session Timer too small
To: <32527700>;tag=4CD1E84-2094
Date: Wed, 29 Jan 2014 22:53:19 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Min-SE:  1800
Server: Cisco-SIPGateway/IOS-15.2.4.M
Content-Length: 0
as per rfc
  If the Session-Expires interval is too low for a proxy (i.e., lower
   than the value of Min-SE that the proxy would wish to assert), the
   proxy rejects the request with a 422 response.  That response
   contains a Min-SE header field identifying the minimum session
   interval it is willing to support.  The UAC will try again, this time
   including the Min-SE header field in the request.  The header field
   contains the largest Min-SE header field it observed in all 422
   responses previously received.  This way, the minimum timer meets the
   constraints of all proxies along the path.
http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-msg_tmr_rspns.html#wp1056968
422 Response Message
If the value of the Session-Expires header is too small, the UAS or proxy rejects the call with a 422 Session Timer Too Small response message. With the 422 response message, the proxy or UAS  includes a Min-SE header indicating the minimum session value it can  accept. The UAC may then retry the call with a larger session timer  value.
If a 422 response message is received after an INVITE request, the UAC can retry the INVITE.
there is two way to fix this issue
1) asked the SBC (your SIP provider) change the value and send standards value in the SIP invite in Session expires
2) Change the value of the Min-SE on the CME with command
run this Global Config on CME
voice service voip
allow connection sip to sip
sip
min-se 90
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Is this a complete logs, i can see only the incoming dial-peer matched ie 1 and nothing .
Can you please collect below output and make a test calls
Debug cssip messages
debug voice ccapi inout
debug voice dialpeer inout
Br,
Nadeem
Thanks, these are the output
Received:
To: <32527700>
CSeq: 1 INVITE
Max-Forwards: 70
Min-SE: 90
Contact: <59513212>
Content-Length: 376
v=0
s=Sip Call
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
*Jan 29 16:53:19: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Jan 29 16:53:19: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Jan 29 16:53:19: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
*Jan 29 16:53:19: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Jan 29 16:53:19: //-1/FB88A7CE80F0/DPM/dpAssociateIncomingPeerCore:
*Jan 29 16:53:19: //-1/FB88A7CE80F0/DPM/dpMatchSafModulePlugin:
Sent:
CSeq: 1 INVITE
Min-SE:  1800
Server: Cisco-SIPGateway/IOS-15.2.4.M3
Content-Length: 0
Received:
ACK sip:32527700@(WAN):5060;user=phone SIP/2.0
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
*Jan 29 16:53:31: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:(SIP_SERVER):5060 SIP/2.0
Via: SIP/2.0/UDP (WAN):5060;branch=z9hG4bK3B11F0F
To: <103>
Date: Wed, 29 Jan 2014 22:53:31 GMT
Call-ID: 3017EE62-885411E3-80B4FEFC-CAA82B4A
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M3
Max-Forwards: 70
Timestamp: 1391036011
CSeq: 66 REGISTER
Contact: <103>
Expires:  3600
Supported: path
Content-Length: 0
*Jan 29 16:53:31: //973/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 400 Bad Request
To: <103>;tag=f2056e8e
CSeq: 66 REGISTER
Content-Length: 0
I´ve replaced the IP Adress for (SIP_SERVER) / (WAN) / SIP_SERVER_INTERNAL
Thank you
Hello ,
You are recieving 400 BAD REQUEST from Peer node. as per RFC 3261
21.4.1 400 Bad Request
   The request could not be understood due to malformed syntax.  The
   Reason-Phrase SHOULD identify the syntax problem in more detail, for
   example, "Missing Call-ID header field".
You can check with ITSP'/ provider with this above error to fix this issue. AFAIK its not an issue with your device
Br,
Nadeem
Call ID:
Received:
To: <32527700>
CSeq: 1 INVITE
Max-Forwards: 70
Min-SE: 90
Contact: <59513212>
Content-Length: 376
v=0
s=Sip Call
t=0 0
a=ptime:20
a=fmtp:18 annexb=no
Sent:
CSeq: 1 INVITE
Min-SE:  1800
Content-Length: 0
as per rfc
voice service voip
sip
min-se 90
Br,
Nadeem
Thank you, thank you so much!!!!
voice service voip
sip
min-se 90
That line fixed the issue
Regards!
You are most welcome:-)
Br,
Nadeem
545
