CUCME Outgoing DTMF from SIP phone to PSTN
Dear all,
2811 Voice router with CME and SIP phone is installed and working.
2 BRI interfaces connects to PSTN (they are no SIP trunk).
When outgoing calls made from SIP Ipphones to an external IVR system, DTMF signals are not sent in order to navigate in voice menu.
The command "dtmf-relay sip-notify" has been applied in "voice register pool" without success.
Please, could you tell me how to configure CME in order to sent outgoing DTMF to PSTN from SIP Phone?
Thanks for your help.
Best regards.
Hall of Fame Super Gold
Re: CUCME Outgoing DTMF from SIP phone to PSTN
The easier way is to configiure the sip phone to not use relay.
Note sip phones actually never use sip-notify.
Thank you for the suggestion.
But technicaly, how to do that?
Any example will be appreciate.
Best regards
In the telephone, configure no DTMF relay.
Same in router.
pdeck,did it work?! can you
pdeck,
did it work?! can you show how u did it?
No solution was found.Context
Context has been changed and CUCME installaton had been removed without resolution. Sorry.
solution for my problem was
solution for my problem was below:
as explained by Paolo
voice register pool  120
 busy-trigger-per-button 2
 id mac xxx.xxxx.xxx
 type 8851
 number 1 dn 120
 cor incoming CALL-NATIONAL default
 dtmf-relay rtp-nte
 username 123123 password 123123
  codec g711ulaw
did you resolve your problem.
did you resolve your problem. and how?
365
