CUCME question
I have a CUCME 9.5 and I am unable to save the config from the GUI. I get the message other telnet session active.
I seem to remember this was a bug in earlier versions is this the case in 9.5.
  • IP Telephony
Blue
CUCME question
I am not sure how is this bug. As far as I know this is working as design.
-Used  command show users, find the telnet sessions.
-Do a clear line < > , in order to delete those sessions.
-Added the following commands also:
1)exec-timeout 10   ( telnet session will be disconnected after 10 min of inactivity)
2)logout-warning 60 (60 sec before automatically logging off router will send warning
message to user to save config)
-Reload the router.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
CUCME question
Thanks I will try what you suggest. I did find a bug for earlier version. I will let you know how it goes.
86
