CUCME sdspfarm units always present even if removed
I've configured transcoders, mtp and conference for a CUCME.
Now I want to remove them.
But after removing transcoder, conference and mtp profiles in the general configuration,
and disabling sccp and i the telephony-service too.
i still see outputs in the "show sdspfarm units" command :
CUCME2851_1#sh sdspfarm units
mtp-1 Device: TCP socket:[-1]  UNREGISTERED
actual_stream:0 max_stream 0 IP:0.0.0.0  0  Unknown 0 keepalive 0
conf-2 Device: TCP socket:[19]  UNREGISTERED
actual_stream:0 max_stream 0 IP:10.71.4.2  50883  Conference Dixieland keepalive 1877
mtp-3 Device:TXC0026CBF8FA40 TCP socket:[7]  UNREGISTERED
actual_stream:0 max_stream 10 IP:10.71.4.2  55975  MTP Dixieland keepalive 55
conf-4 Device:CFB0026CBF8FA40 TCP socket:[19]  UNREGISTERED
actual_stream:0 max_stream 0 IP:10.71.4.2  11461  Conference Dixieland keepalive 40
max-mtps:0, max-streams:0, alloc-streams:0, act-streams:0
CUCME2851_1#
So how to remove them without reloading the router?
Best regards,
Antra
1 REPLY
Re: CUCME sdspfarm units always present even if removed
Can you post the current running configuration of the gateway?
534
