CUCME SIP trunk CUE VM
Hello Friends,
I am in the middle of configuring SIP trunk between 3 sites ( A, B and C). Call between A-B, A-C, B-A, C-A, C-B works perfectly fine but B-C has a wierd issue. The call works but when the call is forwarded to voice mail it plays generic greeting instead of personal greeting. But strangely it does work for couple of extensions.
I have created the below dial-peers: -
For location B: -
dial-peer voice 5000 voip
description DIAL_PEER_TO_MEL
preference 1
destination-pattern 5...$
voice-class codec 1
session protocol sipv2
session target ipv4:X.X.X.X
incoming called-number .
dtmf-relay sip-notify
no vad
At location C: -
dial-peer voice 7000 voip
description DIAL_PEER_TO_BNE
preference 1
destination-pattern 7...$
voice-class codec 1
session target ipv4:10.201.78.1
no vad
for VM
dial-peer voice 999 voip
description -= VOICEMAIL PILOT =-
destination-pattern 5199
session target ipv4:172.16.3.2
session transport udp
codec g711ulaw
no vad
I will also attach the debugs from both ends for a test call (Debug ccsip messages and debug voip dialpeer. Calling number
38457207
Called number: - 5111
Could you please advise what could be the reason for this behaviour and how can we resolve this?
Sam Xavier.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Have you tried adding
no supplementary-service sip moved-temporarily
Under Voice service VoIP
see attached for me detail.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f9666.shtml
Its is odd that it is happening only between calls on the two site
From your debugs the 302 message i last thing seen
Let me know if this was helpful!
Thanks a lot Gregory, that did the trick.
Sam Xavier.
335
