CUCME Version 7.0(1) GUI Problem
Hi, I can't access to CUCME by GUI. When I put the username and the pass, then, the web page get to blank.
The commands web admin system name admin password cisco and ip http server are run.
1 ACCEPTED SOLUTION
Re: CUCME Version 7.0(1) GUI Problem
Please verify that you have the following files on your flash:
Admin-user.html
Admin_user.js
dom.js
ephone_admin.html
normal_user.html
normal_user.js
Telephony_service.html
xml.template
xml-test.html
These are all of the files necessary to enable full GUI functionality.
Hope that helped, if so please rate.
Do you have "ip http path flash:" configured?
Dear Kenneth...Yes
Bronze
Hi to access the GUI and allow the admin to add remove DNs from web interface:
ip http server
ip http path flash:
telephony-service
dn-webedit
time-webedit
Hope this help
David
Cool, I'm going to re-configure and I will show you the result.
Hi..fail. :(. I think that upgrading will be fine.
Hi David
I upgraded to 124-22.T (Cisco 2811), but i still can't access to GUI. I put the user and passw and then it show me the page in blank. Pls.,see the command
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
telephony-service
em logout 0:0 0:0 0:0
max-ephones 42
max-dn 80
ip source-address 10.175.206.1 port 2000
system message CME
user-locale ES
network-locale ES
time-zone 18
time-format 24
date-format dd-mm-yy
voicemail 3120
max-conferences 8 gain -6
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Mar 31 2009 15:20:31
I don't know what happens
Admin-user.html
Admin_user.js
dom.js
ephone_admin.html
normal_user.html
normal_user.js
xml.template
xml-test.html
Dear Kenneth, the problem is solved.
Thanks a lot!!
Hi All,
i have CME version 7.1 with IOS 12.4(24T1)and i experienced the same problem with the GUI interface. i found that the problem came from copying the GUI files using a flash reader, when i uploaded the files using the archive command and used the command ip http server path flash: ,the GUI worked fine but after a restart.
296
