Community Member
CUCMExpress - GUI
Hello Friends
Anybody know where i can get the GUI for Cisco Unified Communications Manager Express 8.0 and how install it?
Thanks in advance for your help
Norman Santana
1 ACCEPTED SOLUTION
Re: CUCMExpress - GUI
Hi Norman,
The updated GUI is included in the CME 8 basic download tar (cme-basic-8.0.0.0.tar) file which is found over at:
Voice and Unified Communications > Cisco Unified Communications Manager Express > Unified Communications Manager Express Complete Support File Set > 8.0
CME 8.0 basic system files for IOS 15.0(1)XA and 15.1.1T releases, includes Basic Phone Loads (7906/11, 7921, 7941/61, 7942/62) with updated GUI for 15.1.1T
If you're talking about a UC500, then click UC500 instead of CUCME.
Kevin P.
Hi Norman,
Kevin P.
Community Member
Thanks Kevin for your help
Norman Santana
Community Member
Yes you have to download the tar package and follow the steps descibed in this document:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmegui.html
Hiep Nguyen,
Community Member
Thanks for your help Hiep Nguyen,
Norman Santana
581
