07-11-2012 04:12 AM - edited 03-16-2019 12:08 PM
Hi Experts please find me a solution for the below debug ccapi inout when i call the companys central number the script does not plays could you please suggest me where to find the exact point of failure.
CUCM4.1, 8 lines terminated at FXO ,CUE2.2.
Jul 7 14:19:47.170: //64243/9FFB63C19F4D/CCAPI/cc_handle_inter_digit_timer:
Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
Annasban-Router#
Jul 7 14:19:56.478: //64237/67CCC3529F47/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Network, Params=0x0, Call Id=64237
Jul 7 14:19:56.478: //64237/67CCC3529F47/CCAPI/ccCallModify:
Nominator=0x1000, Params=0x45B1ADA0, Call Id=64237
Jul 7 14:19:56.478: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x4559FB8C, Call Id=64237
Stop Tone On Digit=FALSE, Tone=Ring Back,
Jul 7 14:19:56.542: //64237/67CCC3529F47/CCAPI/ccGenerateToneInfo:
Jul 7 14:19:56.542: //64237/67CCC3529F47/CCAPI/ccCallModify:
Nominator=0x1024, Params=0x45B1A6F8, Call Id=64237
Jul 7 14:19:56.542: //64238/67CCC3529F47/CCAPI/ccCallModify:
Nominator=0x18E20, Params=0x45B1A840, Call Id=64238
Jul 7 14:19:56.546: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:19:56.546: //64238/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x452F0880, Call Id=64238
Jul 7 14:20:00.914: //64237/67CCC3529F47/CCAPI/ccCallModify:
Nominator=0x1000, Params=0x45B1A6F8, Call Id=64237
Jul 7 14:20:00.914: //64238/67CCC3529F47/CCAPI/ccCallModify:
Nominator=0x800, Params=0x45B1A840, Call Id=64238
Jul 7 14:20:00.914: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:00.918: //64238/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:00.934: //64237/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:20:00.934: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:00.934: //64237/67CCC3529F47/CCAPI/ccGenerateToneInfo:
Jul 7 14:20:25.566: //64243/9FFB63C19F4D/CCAPI/ccCallModify:
Nominator=0x1000, Params=0x45B1A6F8, Call Id=64243
Jul 7 14:20:25.566: //64244/9FFB63C19F4D/CCAPI/ccCallModify:
Nominator=0x800, Params=0x45B1A840, Call Id=64244
Jul 7 14:20:25.566: //64243/9FFB63C19F4D/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x4559DD64, Call Id=64243
Jul 7 14:20:25.570: //64244/9FFB63C19F4D/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x452F0880, Call Id=64244
Jul 7 14:20:25.574: //64243/9FFB63C19F4D/CCAPI/ccCallReportDigits:
Enabled=FALSE, Call Id=64243
Jul 7 14:20:25.574: //64243/9FFB63C19F4D/CCAPI/cc_api_call_report_digits_done:
Enabled=FALSE, Disposition=0x0, Interface=0x4559DD64, Call Id=64243
Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
Jul 7 14:20:25.574: //64244/9FFB63C19F4D/CCAPI/ccGetCallStatistics:
Call Stats=0x4615DA60, Call Id=64244
Jul 7 14:20:25.574: //64243/9FFB63C19F4D/CCAPI/ccConferenceDestroy:
Conference Id=0x7D38, Tag=0x0
Jul 7 14:20:25.574: //64244/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x7D38, Source Interface=0x452F0880, Source Call Id=64244,
Destination Call Id=64243, Disposition=0x0, Tag=0x0
Jul 7 14:20:25.578: //64243/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x7D38, Source Interface=0x4559DD64, Source Call Id=64243,
Destination Call Id=64244, Disposition=0x0, Tag=0x0
Jul 7 14:20:25.578: //64243/9FFB63C19F4D/CCAPI/cc_generic_bridge_done:
Jul 7 14:20:25.578: //64243/9FFB63C19F4D/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 7 14:20:25.578: //64243/9FFB63C19F4D/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Jul 7 14:20:25.578: //64244/9FFB63C19F4D/CCAPI/ccCallDisconnect:
Jul 7 14:20:25.582: //64244/9FFB63C19F4D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x452F0880, Tag=0x0, Call Id=64244,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Jul 7 14:20:25.586: //64243/9FFB63C19F4D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x4559DD64, Tag=0x0, Call Id=64243,
Jul 7 14:20:26.282: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x455A205C, Interface Type=6, Destination=4266644, Mode=0x9,
Call Params(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=4266644(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A0000000010a4924000000F5)
Jul 7 14:20:26.282: //64245/BB271BB99F4E/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jul 7 14:20:26.282: //64245/BB271BB99F4E/CCAPI/ccCallSetContext:
Context=0x46145708
Interface=0x452F0880, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subsriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
Jul 7 14:20:26.282: //64246/BB271BB99F4E/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Jul 7 14:20:26.282: //64246/BB271BB99F4E/CCAPI/ccCallSetContext:
Context=0x46143D70
Jul 7 14:20:26.290: //64245/BB271BB99F4E/CCAPI/cc_api_call_proceeding:
Interface=0x455A205C, Progress Indication=NULL(0)
Jul 7 14:20:26.290: //64246/BB271BB99F4E/CCAPI/cc_api_call_connected:
Interface=0x452F0880, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jul 7 14:20:28.970: //64245/BB271BB99F4E/CCAPI/cc_api_call_cut_progress:
Interface=0x455A205C, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Cause Value=0
Call Entry(Responsed=TRUE)
Jul 7 14:20:28.970: //64245/BB271BB99F4E/CCAPI/ccCallModify:
Nominator=0x1000, Params=0x45B1A9B8, Call Id=64245
Jul 7 14:20:28.970: //64245/BB271BB99F4E/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=64245
Jul 7 14:20:28.970: //64245/BB271BB99F4E/CCAPI/cc_api_call_report_digits_done:
Enabled=TRUE, Disposition=0x0, Interface=0x455A205C, Call Id=64245
Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
Jul 7 14:20:28.970: //64245/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
(confID=0x45B1AB14, callID1=0xFAF5, callID2=0xFAF6, tag=0x0)
Jul 7 14:20:28.970: //64245/BB271BB99F4E/CCAPI/ccConferenceCreate:
Conference Id=0x45B1AB14, Call Id1=64245, Call Id2=64246, Tag=0x0
Jul 7 14:20:28.974: //64246/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x7D39, Source Interface=0x452F0880, Source Call Id=64246,
Destination Call Id=64245, Disposition=0x0, Tag=0x0
Jul 7 14:20:28.974: //64245/BB271BB99F4E/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x7D39, Destination Call Id=64246)
Jul 7 14:20:28.974: //64246/BB271BB99F4E/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x7D39, Destination Call Id=64245)
Jul 7 14:20:28.974: //64245/BB271BB99F4E/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x455A205C, Call Id=64245
Jul 7 14:20:28.974: //64245/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Conference Id=0x7D39, Source Interface=0x455A205C, Source Call Id=64245,
Destination Call Id=64246, Disposition=0x0, Tag=0x0
Jul 7 14:20:28.974: //64245/BB271BB99F4E/CCAPI/cc_generic_bridge_done:
Jul 7 14:20:28.974: //64245/BB271BB99F4E/CCAPI/cc_api_caps_ind:
Destination Interface=0x452F0880, Destination Call Id=64246, Source Call Id=64245,
Caps(Codec=0x6EFFF, Fax Rate=0xFF, Vad=0x3,
Modem=0x2, Codec Bytes=0, Signal Type=3)
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=250(ms), Fax Nom=300(ms))
Jul 7 14:20:28.974: //64246/BB271BB99F4E/CCAPI/cc_api_caps_ind:
Destination Interface=0x455A205C, Destination Call Id=64245, Source Call Id=64246,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
Jul 7 14:20:28.974: //64246/BB271BB99F4E/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1623)
Jul 7 14:20:28.978: //64245/BB271BB99F4E/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x7D39, Call Id1=64245, Call Id2=64246
Jul 7 14:20:28.978: //64245/BB271BB99F4E/CCAPI/cc_api_caps_ack:
Jul 7 14:20:28.978: //64245/BB271BB99F4E/CCAPI/cc_api_call_connected:
Interface=0x455A205C, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
Jul 7 14:20:28.978: //64245/BB271BB99F4E/CCAPI/cc_api_voice_mode_event:
Call Id=64245
Call Entry(Context=0x46145708)
Jul 7 14:20:28.982: //64245/BB271BB99F4E/CCAPI/ccDigitDialStop:
Call Id=64245
Jul 7 14:20:28.982: //64245/BB271BB99F4E/CCAPI/cc_api_dialing_complete:
Return Value=FALSE, Interface=0x455A205C, Call Id=64245
Call Id=64245
Jul 7 14:20:29.078: //64245/BB271BB99F4E/CCAPI/ccSetDigitTimeouts:
Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
Jul 7 14:20:29.078: //64245/BB271BB99F4E/CCAPI/ccRestartDigitTimeoutMsec:
Digit Timeout=0, Call Id=64245
Jul 7 14:20:29.078: //64245/BB271BB99F4E/CCAPI/ccCallReportDigits:
Jul 7 14:20:29.078: //64245/BB271BB99F4E/CCAPI/cc_api_call_report_digits_done:
Jul 7 14:20:29.078: //64245/BB271BB99F4E/CCAPI/ccCallModify:
Nominator=0x102C, Params=0x45B1A6F8, Call Id=64245
Jul 7 14:20:29.078: //64246/BB271BB99F4E/CCAPI/ccCallModify:
Nominator=0x18E20, Params=0x45B1A840, Call Id=64246
Jul 7 14:20:29.078: //64245/BB271BB99F4E/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:29.082: //64246/BB271BB99F4E/CCAPI/cc_api_call_modify_done:
Result=0, Interface=0x452F0880, Call Id=64246
Jul 7 14:20:33.079: //64245/BB271BB99F4E/CCAPI/cc_handle_inter_digit_timer:
Jul 7 14:20:41.039: //64237/67CCC3529F47/CCAPI/ccGenerateToneInfo:
Jul 7 14:20:41.043: //64237/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:20:41.043: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:41.043: //64237/67CCC3529F47/CCAPI/ccGenerateToneInfo:
Jul 7 14:20:41.107: //64237/67CCC3529F47/CCAPI/ccGenerateToneInfo:
Jul 7 14:20:41.107: //64237/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:20:41.107: //64238/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:20:41.107: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:41.107: //64238/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:45.599: //64237/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:20:45.599: //64238/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:20:45.599: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:45.599: //64238/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:45.615: //64237/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:20:45.619: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:45.619: //64237/67CCC3529F47/CCAPI/ccGenerateToneInfo:
Jul 7 14:20:47.211: //64245/BB271BB99F4E/CCAPI/ccCallModify:
Nominator=0x1000, Params=0x45B1A6F8, Call Id=64245
Jul 7 14:20:47.211: //64246/BB271BB99F4E/CCAPI/ccCallModify:
Nominator=0x800, Params=0x45B1A840, Call Id=64246
Jul 7 14:20:47.211: //64245/BB271BB99F4E/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:47.211: //64246/BB271BB99F4E/CCAPI/cc_api_call_modify_done:
Jul 7 14:20:47.219: //64245/BB271BB99F4E/CCAPI/ccCallReportDigits:
Enabled=FALSE, Call Id=64245
Jul 7 14:20:47.219: //64245/BB271BB99F4E/CCAPI/cc_api_call_report_digits_done:
Enabled=FALSE, Disposition=0x0, Interface=0x455A205C, Call Id=64245
Jul 7 14:20:47.219: //64246/BB271BB99F4E/CCAPI/ccGetCallStatistics:
Call Stats=0x4615CFC0, Call Id=64246
Jul 7 14:20:47.219: //64245/BB271BB99F4E/CCAPI/ccConferenceDestroy:
Conference Id=0x7D39, Tag=0x0
Jul 7 14:20:47.219: //64246/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jul 7 14:20:47.219: //64245/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jul 7 14:20:47.219: //64245/BB271BB99F4E/CCAPI/cc_generic_bridge_done:
Jul 7 14:20:47.219: //64245/BB271BB99F4E/CCAPI/ccCallDisconnect:
Jul 7 14:20:47.223: //64245/BB271BB99F4E/CCAPI/ccCallDisconnect:
Jul 7 14:20:47.223: //64245/BB271BB99F4E/CCAPI/cc_api_get_transfer_info:
Jul 7 14:20:47.223: //64246/BB271BB99F4E/CCAPI/ccCallDisconnect:
Jul 7 14:20:47.223: //64246/BB271BB99F4E/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x452F0880, Tag=0x0, Call Id=64246,
Jul 7 14:20:47.231: //64245/BB271BB99F4E/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x455A205C, Tag=0x0, Call Id=64245,
Jul 7 14:21:25.736: //64237/67CCC3529F47/CCAPI/ccGenerateToneInfo:
Jul 7 14:21:25.736: //64237/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:21:25.736: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:21:25.800: //64237/67CCC3529F47/CCAPI/ccGenerateToneInfo:
Jul 7 14:21:25.804: //64237/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:21:25.804: //64238/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:21:25.804: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:21:25.804: //64238/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:21:30.160: //64237/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:21:30.164: //64238/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:21:30.164: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:21:30.164: //64238/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:21:30.180: //64237/67CCC3529F47/CCAPI/ccCallModify:
Jul 7 14:21:30.180: //64237/67CCC3529F47/CCAPI/cc_api_call_modify_done:
Jul 7 14:21:30.180: //64237/67CCC3529F47/CCAPI/ccGenerateToneInfo:
07-11-2012 05:02 AM
Check router and CUE configuration.
07-13-2012 11:04 PM
My above issue is resolved but I want to make Incoming calls busy when all the FXO lines have been used for Incoming calls it is keep on ringing and running the script in CUE2.2 is it depends on max sessions 8 but on the FXO only 7 lines are connected. do i need to make max session 7 to make the 8 incoming call busy instead of ringing.
ccn trigger jtapi phonenumber 7100
application "autoatt"
enabled
maxsessions 8
end trigger
07-14-2012 03:20 AM
Tha4 indicates thar not all the lines are busy, otherwise CUE would not receive the call.
In other words, rhe is no need to use max sess, it's automatic.
