Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CUE 3.1 upgrade and flash
Hi all,
I need to upgrade a AIM-CUE 3.1, to hopefully 7.1.x. question:
1, according to Cisco docs, if the AIM-CUE has got 512MB compact flash, it needs to upgrade to 1G first. how do I check the how much is the flash now? I went through all the commands and even "show tech" on the module, can't find the flash size.
2, if I do a upgrade (not clean install), do I need to do anything about licenses??
thanks
1 ACCEPTED SOLUTION
Re: CUE 3.1 upgrade and flash
1. you can use show voicemail limits
if System Capacity (minutes): 480
then it is 512
480/60=8-hours storage
if 14-hour storage ,then it is 1GB
2. no
wish this be helpful
then it is 512
2. no
hi,
this may clarify my post above:
CUE#show voicemail limits
Default Mailbox Size (seconds): 420
Default Caller Message Size (seconds): 60
Maximum Recording Size (seconds): 900
Default Message Age (days): 30
Default Prompt Language: en_US
Operator Telephone: 0
Thanks! I ran that commands, it shows the system capacity as 800 min, so I guess it's a 1GB flash one.
For the license, I found that since CUE 7.1, the licensing changes to the new scheme, you buy the mailbox license in increments of 5, etc. I thought since it's different from before, don't you need to get new license file or something like that??
yes
I have an upgrade like that lately
and i didn't deal with any upgrade license file
it is only if you'll change the no. of supported mail boxes
thanks
I believe you can see compact flash information with show version from cue prompt.
Hope it helps, if it does please rate.
Best regards,
- Adrián.
thanks for your reply, I thought the show version command would show it, but it shows SDRAM not flash size.
Thanks for your confirmation.
- Adrián.
200
