07-10-2009 07:53 AM - edited 03-15-2019 06:55 PM
I have CUE 7.0.1 (NME-CUE) in a 2821. I configured the following
interface Integrated-Service-Engine1/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.32.128.23 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 10.32.128.11
no keepalive
ip route 10.32.128.23 255.255.255.255 Integrated-Service-Engine1/0
The problem I'm having is that I can't access the service-module IP, not even from the router... what did I miss?
07-10-2009 08:00 AM
What error are you getting?
07-10-2009 08:01 AM
no error, can't even ping 10.32.128.23 at this point.
07-10-2009 08:19 AM
what do you get when you issue
service-module service-engine 1/0 status?
does the interface show up/up?
07-10-2009 08:46 AM
Service Module is Cisco Integrated-Service-Engine1/0
Service Module supports session via TTY line 66
Service Module is in Steady state
Service Module heartbeat-reset is enabled
Getting status from the Service Module, please wait..
Cisco Unity Express 7.0.1
CUE Running on NME
07-10-2009 09:21 AM
Does the please wait ever go away? Also Im assuming you did a shut/no shut on the interface already. You may want to try reseating the NME-CUE.
07-10-2009 11:25 AM
"please wait" never changes. I tried shut/no shut several times. I re-seated the card and still nothing. I may just open a TAC case, thanks for your help.
08-24-2009 04:56 AM
Were you ever able to get this working? I'm running into the exact same situation.
--Brandon
02-22-2010 11:06 AM
I have the same problem.
How do you resolv this issue?
tks
02-22-2010 12:20 PM
Wrong config.
Send it.
02-22-2010 02:32 PM
This is my config,
I can't ping 10.247.93.153
help me please!!!
tks
interface GigabitEthernet0/0
description Lan
ip address 10.247.93.150 255.255.254.0
ip helper-address 10.247.98.219
ip helper-address 10.247.100.1
duplex auto
speed auto
media-type rj45
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.247.93.150
interface Integrated-Service-Engine2/0
service-module ip address 10.247.93.153 255.255.254.0
service-module ip default-gateway 10.247.93.150
no keepalive
02-22-2010 02:49 PM
You do not have the host route for the module.
02-23-2010 02:42 AM
Hi Guys..
You need to add the static route for the Service Engine module. For example Service Engine Module IP address is 10.68.90.4 you need to add below static IP address.
Router(config)# ip route 10.68.90.4 255.255.255.255 Integrated-Service-Engine1/0
Note:Please see the mask in the route..
Vaijanath
02-25-2010 07:02 AM
Tks all.
I add the static route, and ping succesfull.
But the browser with ip address of "CUE" don't response.
Any idea?
