CUE 7.0.3 GUI Wizard
I have done a clean install if 7.0.3
created the admin account and password
Able to log into the gui and I am presented the CUE wizard. I can ping everything from the cue prompt and use the user in teleyphoney-service as the web admin.
But I am getting web login failure.
the cue ip is 10.10.203.2
Re: CUE 7.0.3 GUI Wizard
Try putting the admin username/password. I think this is required for this part of the install.
Hope that helped, if so please rate.
I tired that as well, and still get the same error
Bronze
Hi friend, to access the CUE GUI, you need the username and password that you have configured during the CLI CUE wizard configuration.
All the best
David
I have also tried that :)
Bronze
Hi, sorry I misunderstand your question. Make sure that you have configured this commands:
#ip http server
#telephony-service
- dn-webedit
- time-webedit}
Hope this help
David
Bronze
this is prompting you for a Call Manager Integration setup. based on what you have here you are using CCME and therefore you need the CCME license (Downloadable once you have the cco login).
basically you have the wrong license. you have CCM and you should have CCME.
this is for a old version (just did a google searc hand chose the first one) but will also apply
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_3/install/upg_lic.html
Damm, how come in did not notice that
Many thanks
Bronze
not a prob at all :)
236
