CUE 8.5 with CUCM 8.5
we have an issue with our CUE.
Internal calls to the CUE and leaving a voicemail for someone from a internal deskphone works fine. Only external calls will be terminated with a fast busy tone. I couldn’t find much information about CUE interacting with CUCM.
As I remember what I learned the CUE needs a SIP trunk to CUCM. At the moment there is no SIP trunk for CUE configured. But in that case was wondering that internal calls work fine. Any idea what I can check or what I can debug on the CUE?
thanks
Eike
Everyone's tags (3)
VIP Super Bronze
What tyoe of gateway are you using..is can you send a
debug voip ccapi inout Please send the calling and called number..
Can you also send a sh run of your gateway?
What codec do you have on your inbound dial-peer to the gateway and your outbound dial-peer from the gateway to cucm
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: CUE 8.5 with CUCM 8.5
it is 2821 mgcp gateway.
there is no problem for normal incoming calls. Phone rings and after the NOAN duration it just gives a fast busy. So I guess it is something in call manager and not on the gateway.
I should maybe mention that it was working before, with CUE 3 or 4 (can't remember) and CUCM 7.1
Codec we use is G711
Eike
VIP Super Bronze
can you do a test call and send cucm traces..ensure trace is set to detail
287
