CUE 8.6 web interface cannot control CME phone
Dear Member,
I got some problem when using CME 8.5 with CUE 8.6, everything is fine except I can't find any way to config or modify the setting such as add a IP phone on CUE link.
As I m using CME and CUE version 7 before, CUE web link can add and modify some simple CME setting.
May I know this version cut off those feature?
Any member face this problem?
Russ
Re: CUE 8.6 web interface cannot control CME phone
Dear Member,
It should be missing the "Phone" and "Extension Menu" on Config colume.
Russ
Hall of Fame Super Gold
Disregard GUIs.
For professional results, only use CLI to configure CME.
Hall of Fame Super Red
Hi Russ,
This changed with the release of CUE 8.x;
Removal of Support for Cisco Unified Communications Manager Express GUI Functionality
Beginning with Cisco Unity Express 8.0, the Cisco Unity Express GUI no longer provides functionality for configuring Cisco Unified Communications Manager Express. Cisco recommends using Cisco Configuration Professional (CCP) to configure Cisco Unified Communications Manager Express.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel8_0/rel_notes/rel_notes.html#wp339722
Cheers!
Rob
722
