Community Member
CUE AA query
Can a CUE Auto-Attendant work without any "Call-in Number" configured?
Is there any chance the system might play some default .wav files in the default AA script when all extensions are busy & the call is forwarded to Voice Mail?
1 ACCEPTED SOLUTION
Re: CUE AA query
u can make custimized msg
in the phon level u have the option to forward the when the line is budy and when no answer to a number which should be a voice mail number such as cue
Re: CUE AA query
u have to have a number for voicemail to get it work
have a look at this link to understand it and will be helpful too
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a00804dfe88.shtml
good luck
please, if helpful rate
Community Member
Re: CUE AA query
Marwan,
Thanks for the reply. Is it possible for CUE Auto-Attendant to play a customized message saying " all lines are currently busy" when no one is answering the call?
Ashok.
Re: CUE AA query
Community Member
Re: CUE AA query
Marwan,
Thanks a lot. This helps a lot.
Ashok.
134
