CUE AA query
Is it possible to reduce the volume of the Auto-Attendant .wav files ? Users are complaining that the volume is too high.
Hall of Fame Super Gold
Re: CUE AA query
Either use any sound editor, or increase output attenuation under voice-port.
Re: CUE AA query
Thanks for the info Paolo - regarding the statement "increase output attenuation under voice-port" do you have the command sequence for it ?
Thnnx,
Ashok.
Super Bronze
Re: CUE AA query
Under voice-port:
Output attenuation
Maybe start with '3', and reassess whether it needs increasing...
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Re: CUE AA query
Thanks Aaron, that's extremely helpful. Just one more help - could you please give a sample config for this ?
163
