CUE AA Scripting question
Hi all,
Is it possible to create a CUE AA script that will do the following:
- Dial ext. at any time
- Press 2 do spell by name directory
- Press 0 to transfer to the operator
- Press # to transfer to voice mail pilot number to access your voicemail
- Press * to transfer to an extensions voicemail
- If no option selected, leave a message in general voice mail box
I know this can be done with Unity, but can you do with this Unity Express? Would anyone have a scripot currently that does most of this? I have installed the CUE Editor, but haven't tried to create my own script yet (still trying to figure out what to do...).
Also, is there a web site that has scripts you can download?
Thanks for your help!
Scott
  • IP Telephony
Re: CUE AA Scripting question
Scott,
Yes, this is possible. The attached sample script does most of this. Also, go to the following link and then to your version of CUE for some other sample scripts.
http://www.cisco.com/kobayashi/sw-center/sw-voice.shtml
Hope this helps. If so, please rate the post.
Brandon
Hi Brandon,
Thanks for your reply and the script. I'll take a look at it and let you know how I make out.
Thanks again for your help!
Scott
114
