CUE AA transfer to B-ACD script no sound
Hello Community,
I am having an issue with AA and B-ACD.
When a call comes in, it is sent to AA, which is only used to check the time. If the time falls between the opening hours, then transfer to the B-ACD script, running on the CME.
The caller then gets the menu prompt played, and they click their option. The user is then placed into the queue. They hear the MOH, and all is good.
Then the operator picks up the handset, and the call is connected. The call however is silent. No communication can be heard by either party.
I am able to tell when this is going to occur, as the terminal monitor shows the following:
VCC, mtp1 index, mtp2 index, stream1, stream2 = 0 0 5 6 VCC, mtp1 index, mtp2 index, stream1, stream2 = 0 0 6 5
Any Ideas?
Many Thanks!
Joe
  • IP Telephony
1 ACCEPTED SOLUTION
Hmm ok.. can you try changing
Hmm ok.. can you try changing it to blind refer?
I was able to reproduce this,
I was able to reproduce this, using my mobile phone. I am able to hear the CME phone talking on my mobile, but the ip phone cannot hear the mobile phone.
HelloCan you share the
Hello
Can you share the configuration of the CME ?.
please rate all useful information
Hi, Please find attached my
Please find attached my config.
Joe
HelloCan you find the below:
Hello
Can you find the below:-
dial-peer voice 2000 voip
 service aa
 destination-pattern 7000
 session target ipv4:192.168.0.218
 incoming called-number 7000
 no voice-class codec 1 offer-all
codec g711ulaw
thanks
please rate for all useful information
Thanks. I shall test it, and
Thanks. I shall test it, and come back to you. BTW, I need dtmf-relay h245-alphanumeric, as otherwise the user cannot select a menu option :)
I understand why it should be G711u, but As I have Voice Class Codec 1, I had presumed it would look through that for the correct codec? How come this is not the case?
Joe
hi sorry i forget to add it ,
hi
sorry i forget to add it , just i need to show g711ulaw .follow the below
 service aa
codec g711ulaw
 no vad
thanks
I already added it back in.
The call is still single way audio though, sometimes...
Hello1-dial-peer voice 2000
Hello
1-dial-peer voice 2000 voip
 service aa
 session target ipv4:172.25.100.254  / i used the ip address of your CME/
codec g711ulaw
 no vad
2-Lets do also debug voice ccapi inout & debug ccsip messages
Can you elaborate on
Can you elaborate on "sometimes"? Does this mean there is 2 way audio also?
Can you take packet captures on the router physical interface towards the WAN?
Here's a document on taking the captures:
supportforums.cisco.com/docs/DOC-32870
383
