Community Member
CUE AA user hits 0 for opertaor they xfer to Ext which gos to no VM
I remeber reading somewhere on CCO wherby calls to CUE redirected cant comprehend reset the original called party number to redirecting number.
The scenario is this customer calls in to AA they select 0 for operator the call is redirected to operator ,first engineer has used the Reset CTI Called Address in script" default"
Then the operator answers the call and blind tranfers to a internal user extension who doesnt answer and the call which then rolls over to VM and says there is no mail box available for this user "which there is"
I assume that CUE is seeing the call coming from the operator is this correct and if so how to rectify the situation so that final call party "the user" whom the opertaor transfered to will be the number CUE sees
Allan
Community Member
Re: CUE AA user hits 0 for opertaor they xfer to Ext which gos t
TAC advised it cant be done great design brilliant even.
it would be great to get CUE working in the same manner unity Does with CM. For transfered calls which fwd noans /busy to VM.
I reckon it might work with COR Dial-peers and voice-translations
Get some time I'll test it out.
Is there internal users using
Is there internal users using "ephone-dn" or "voice register dn"?
Yosh
HTH Regards, Yosh
241
