cue access
i have cue where i can access from command line through the router, no password at this stage when login to cue.
i am wondering how to know what is the username and password for the web cue access or at least can i set a new username and password for web access.
Good day
1 ACCEPTED SOLUTION
Re: cue access
The following link should help.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_password_recovery09186a008042aa29.shtml
Hope this helps. If so, please rate the post.
Brandon
Re: cue access
Brandon
Re: cue access
Look in the configuration under telephony-services in the running config of the router. If gui access has been setup, you will see the statement
"web admin system name [login name] [password | secret] xxxx"
if its not there, you can configure it and this will be the username/pw for gui access to cue.
Hope that helped
147
