CUE and 2007 DST time zone changes
Anyone know if there is anything on CUE that needs to be done before this change or is there going to be a update or patch?
Thanks.
Green
Re: CUE and 2007 DST time zone changes
CUE automatically detects the daylight savings based on the timezone selected in the set up (post install). You do not need to do or configure anything beyond the timezone info and the NTP servers where
the clock info is sourced from.
I have done some research and here are the IOS's that adopt new default summer-time rules from Energy Policy Act.
Unity Express
4.0(1), 2.0(4.2), 2.0(2.6), 2.0(2.7), 2.0(4.1)
If you are using CME as aN NTP I believe this is the command you need:
clock summer-time CST date Mar 23 2007 23:59 Nov 4 2007 23:59
Ok. Thanks for the info.
I was mainly checking because of the Indiana timezone changes in past that needed a new CUE software version.
363
