CUE and SRST
I have a remote site with a CUE that is the primary Voice Mail. That seems to be working ok.  However when the site fails over to srst. We have two issues.
1- when you call another extension and it forwards to voicemail it does not go to the forwarded phones mailbox instaed it tries to log into the mailbox and gives the "Please enter your Pin" . However in normal mode it works fine.
2- We have POTS line that ring to an AA setup on the CUE, In SRST mode it does not allow a user to call an extension from the AA. Instead of transferring the Call it goes right to the users Voice Mail.
Any suggestions would be appreciated.
Ken
Re: CUE and SRST
Ken,
Is the CUE integrated with CUCM? If so, is this JTAPI integration?
If this is JTAPI integration then I do not think that this wil work, since when in SRST CUE needs to be integrated as SIP. Further thoughts are welcomed in this regards.
You may also wish to check - http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/design/design21/cuemodel.html
Suggestions are welcomed.
Udit
Re: CUE and SRST
Thanks for the response.
I am using UCM as my call control, and Jtapi as the CUE connection to UCM. I just followed this DOC:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml
So you are saying if we switch to SIP it should start working? Is there a good Doc on how to set that up?
Ken
Re: CUE and SRST
Ken,
CUE can run either in CUCM or CCME mode. This depends on the license that is installed on CUE. This also decides if the integration would be JTAPI or SIP.
Since the CUE is integrated with CUCM, you need CCM licenses and hense this is JTAPI integration.Now with JTAPI would not work with SRST mode.
If you check, http://www.cisco.com/en/US/partner/products/sw/voicesw/ps5520/products_configuration_example09186a0080289ef0.shtml#srst
you can configure SIP dial-peers on SRST router which should ideally send the call to CUE and you should not lose your VM and AA. Along with dial-peers you will have to configure voicemail and CFNA and CFB under call-manager-fallback as shown in above link.
You will also have to create SIP triggers within CUE as show in the guide.
ASFAIK, when in SRST, MWI would not work for the IP Phones.
HTH.
Udit
1739
