04-11-2010 11:55 AM - edited 03-15-2019 10:12 PM
Does anyone have an example script for CUE 7.0? CCO is having some example scripts, but I can't find any dial by extension scripts. I see the dial by extension option in the media folder of CUE editor but I can't get it to work. What I am looking for is this:
Check for office hours (no> voicemail) >
Welcome, dial 1 for English, dial 2 for Spanish >
Main Menu (desired language)
You may dial an extension at any time (1XXX), press 2 for department A, press 3 for department B.
Thanks in advance,
Solved! Go to Solution.
04-12-2010 06:45 AM
Hi Jeroen,
No worries my friend
Have you tried these resources?
Unity Express Custom Scripts Quick Start Guide
Note: Custom script support is not available through the regular Cisco Technical Support. For questions, comments, and help with a custom script, send an email to;
ask-cue-editor@external.cisco.com.
Cheers!
Rob
Please support CSC Helps Haiti
04-12-2010 05:54 AM
Hi Jeroen,
The "Example" scripts can be found @ this path
Cisco> Support> Tools and Resources> Software Downloads> Voice and Unified Communications> Unified Communications Applications> Voice Mail and Unified Messaging> Cisco Unity Express Version 7.0> Unity Express Auto-Attendant Scripts> 7.1.1> CUE-AA-S4-DialbyName-2.3.1.zip
Cheers!
Rob
04-12-2010 06:26 AM
Thanks for your answer.
I just tried that script but that is only having a dial by name option, no dial by extension...
- Jeroen
04-12-2010 06:45 AM
Hi Jeroen,
Cheers!
Rob
05-08-2010 12:00 PM
Hi Rob,
Thanks, I used you document in combination with an example script which is recently uploaded in the 7.1.5 example script folder. The script is working fine now.
