Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CUE Change Default Language
Hi All
We're running CUE 2.3 (Aim) with US Language. Can anyone tell me how I can change this to UK language?
I've downloaded UK language pack from cisco.com but it looks to me like I can't simply install the additional language and make that the default. Instead I must reinstall all the software on the module. Is this correct?
Thanks In Advance
1 REPLY
Hall of Fame Super Red
Re: CUE Change Default Language
Hi Anthony,
Have a look at the method listed at this link that detals changing the CUE Language without losing all existing data;
Frequently Asked Questions
I have a working system and I want to change the language (while saving all the data on the system). Which procedure do I need to follow?
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008064172a.shtml#qa1
Hope this helps!
Rob
189
