CUE CME AA
Hi guys,
i am looking to see if i can have an AA (either tcl or CUE) where a person calling in can hear a prompt (ex: welcome to Cisco, transfering please wait) and after the prompt we can ring an extension or a hunt list.
thanks
Good day
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: CUE CME AA
Hi, if you read the "guide to writing AA scripts" for CUE, there is the default script commented and all the "steps" are explained.
Thanks for the rating and good luck!
Re: CUE CME AA
Sure, for B-ACD/AA is called drop-through mode, for CUE you need to write your own custom script.
Re: CUE CME AA
Hi and thanks,
i am wondering with CUE what exactly should we use in the script for that to work.
Good day
Re: CUE CME AA
149
