Community Member
CUE / CME - Calls which RNA to vmail don't go to subsriber mailbox
Can someone point me in the right direction? I have 2 3945 routers with CME / CUE. If call originates on router 1 and RNA to voicemail, it works. If call originates on Router 2 and uses voip dial-peer to go to router 1 I just hit the general pilot "Welcome to Unity...". Is there something that needs to be added to my dial-peer? I think something is not being carried over. Please help. Thanks in advance!
Kelly
Here are the involved dial-peers for my vm pilot and intergateway calls (the same on both routers):
dial-peer voice 1 voip
mailbox-selection orig-called-num
destination-pattern 31111
b2bua
session protocol sipv2
session target ipv4:xxx.xxx.xxx.xxx (CUE address)
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 5 voip
corlist outgoing 8XXXX-Al-pt
description All 8xxxx on router 1
destination-pattern 8....
Everyone's tags (4)
440
