CUE configuration with vrf
We are having a vrf configuration on a 2911 router which is doing CME and CUE functionality too.
I was able to configure the vrf on the telephony service and the phones are wokring just fine. But I am having trouble configuring the CUE module on the ISM interface. I didnt find any guides for ISM interface but I found for service module configuration and I did apply it to the ISM but it is not working.
The other thing is the routing.
ip route 10.30.200.5 255.255.255.255 ISM0/0
I have to change this somehow to:
ip route vrf TRUST 10.30.200.5 255.255.255.255 ISM0/0
...but it doesnt accept it. Says I have to route to a destination IP not to a module because this is not a point to point link.
interface ISM0/0
ip vrf forwarding TRUST
ip unnumbered GigabitEthernet0/1.200
service-module ip address 10.30.200.5 255.255.255.0
!Application: SRSV-CUE Running on ISM
service-module ip default-gateway 10.30.200.1
interface GigabitEthernet0/1.200
description ##### VOICE_VLAN #####
encapsulation dot1Q 200
ip address 10.30.200.1 255.255.255.0
ip access-group EDEN_ACL_IN_G0/1.200 in
ip nat inside
ip virtual-reassembly in
telephony-service
group 1 vrf TRUST
  ip source-address 10.30.200.1 port 2000
no auto-reg-ephone
max-ephones 15
max-dn 30
timeouts interdigit 2
system message Eden - Welcome
load 7962 SCCP42.9-1-1SR1S
load 7975 SCCP75.9-1-1SR1S
time-zone 30
voicemail 299
mwi relay
max-conferences 8 gain -6
web admin system name zenith secret 5 $1$hjdB$Sf3S4BN./NyZ0tWPq/w.M0
transfer-system full-consult
create cnf-files version-stamp 7960 Dec 01 2011 21:46:30
Thank you advance for the comments!
Gergely
I need to ask about something
why you need to use VRF with the CUE
Aren't you able to configure the telephony-service and CUE to not being related to the VRF conf ?
Haitham
Re: CUE configuration with vrf
Check out this link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevrf.html
426
