Community Member
cue dial by name directory
Hello, have a new cue setup and I would like to change the dial by name directory to use the first name. is this something i'm going to have to script or is there a command that i can set this easily? thanks in advance!
Hall of Fame Super Red
Re: cue dial by name directory
Community Member
I can easily get around the prompt by recording over it, Mark referenced a workaround for swapping first name and last name entries, but i don't see a place in rhe CUE for these entries. would that be in the username entry or on the mailbox itself?
Hi Cheramie,
I hate to keep referencing info from Markus, but he says it better than I could ever hope to :)
"The only way to search by first name is simply to reverse the first name/last name in each user's profile. Those fields are not used anywhere else, so it's not that big of a deal."
From this excellent (older) thread;
Hope this helps! And good luck!
