CUE direct transfer to VM with no E164 option
I would like to setup direct transfer to voice mail in CUE.
I'm already using the E164 for DID assigment so that's not an option. Looks like I will have to go with a translation rule my dial plan is 3 digits begining with 1.. and the E164 number begins with 834221....
Can you help with an example.
thanks
Armando
Re: CUE direct transfer to VM with no E164 option
Armando,
Another option is to use the custom script which can be obtained by sending an email to ask-cue-editor@external.cisco.com. See the following link for details on the script and its use.
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps5520/products_tech_note09186a00802ab979.shtml
Hope this helps. If so, please rate the post.
Brandon
i figure it out. 8 plus the 3 digit extension.
voice translation-rule 1
rule 1 /^8\(.*\)/ /\1/
voice translation-profile extra_extn
translate redirect-called 1
dial-peer voice 1 voip
translation-profile outgoing extra_extn
preference 1
destination-pattern 6000
session protocol sipv2
session target ipv4:10.66.81.94
incoming called-number .
dtmf-relay sip-notify
codec g711ulaw
no vad
ephone-dn 6 dual-line
number 81..
call-forward all 6000
Armando
142
