CUE DTMF ISSUE
One of our client has C2911 router with CME. The telephony ver is 8.8.
We installed an ISM module in the router but the AA does not accept DTMF tones. I will appreciate your sugegstions to help me fix this problem.
CME#sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(1)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 18:24 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
CME uptime is 17 minutes
System image file is "flash0:c2900-universalk9-mz.SPA.152-1.T.bin"
Cisco CISCO2911/K9 (revision 1.0) with 475136K/49152K bytes of memory.
Processor board ID FCZ1527707J
4 Gigabit Ethernet interfaces
2 terminal lines
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXS interfaces
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
   Cisco Unity Express 8.6.1 in slot/sub-slot 0/0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FCZ1527707J
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    RightToUse     securityk9
uc            uck9          Permanent      uck9
data          None          None           None
CME#sh telephony-service
CONFIG (Version=8.8)
Version 8.8
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
R
Ibrahim SAYEED
Everyone's tags (6)
1 ACCEPTED SOLUTION
VIP Super Bronze
CUE DTMF ISSUE
Hi, before we do nay trouble shooting, your confiuration is missing key parameters.
1. There is dial-peer for incoming calls from your sip provider.
2. If it is this dial-peer you are using or this may be matched is the dialed number is 77.... then there is no dtmf-type ocnfigured on it
dial-peer voice 100 voip
description Office Extensions
translation-profile incoming AA-TEST
destination-pattern 77....
session target ipv4:192.168.80.1
codec g711ulaw
3. I suggest you do the ff:
dial-peer voice xxxx voip--------xxxx=whatever dial-peer number you choose
incoming called number .
session protocol sipv2
dtmf-relay rtp-nte
no vad
If it still doesnt work, then I need to confirm what SIP provider are you using..is it Huwaei? If it is so, this is a common problem with them
can you send
debug ccsip messages
debug voip rtp session named-event
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Silver
Re: CUE DTMF ISSUE
Can you post "sh run" from the router?
Make sure your dial peers for CUE use proper dtmf method.
CUE DTMF ISSUE
Make sure the voip dial-peer to CUE is configured with dtmf-relay sip-notify too.
CUE DTMF ISSUE
Hello Ibrahim,
Please issue the command "show ccn subsystem sip", on CUE, you'll find the DTMF method configured on CUE. Make sure that the dial-peer pointing to CUE use the same DTMF method.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Re: CUE DTMF ISSUE
Thanks for your suggestions @Chris, Joe & Jorge.
I have configured CME+CUE in past but never came across such an issue. I had checked the CCN subsystem sip configuration and already mentioned sip notify as the DTMF method to be used.
Could this be a problem related to SIP configuration under voice service voip which i have configured first time to register 9951 & 9971 IP phones.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  bind control source-interface GigabitEthernet0/0.10
  bind media source-interface GigabitEthernet0/0.10
  registrar server expires max 3600 min 120
  asymmetric payload full
Attached is the full configuration.
VIP Super Bronze
CUE DTMF ISSUE
codec g711ulaw
dtmf-relay rtp-nte
no vad
can you send
Re: CUE DTMF ISSUE
@aokanlawon
Thanks for your suggestion. It helped me solve my problem. The provider missed dtmf settings at their side. Now issue is resolved with no changes required at my end.
Thanks All again.
2492
