03-03-2007 11:42 PM - edited 03-14-2019 08:18 PM
A user wants un-answered calls to be forward during the night to a different voice mailbox. During the day he wants the calls to be forwarded to his primary mail box.
What is the best way to do this in your opinion?
03-04-2007 01:09 AM
Probably the easiest way would be to use the ACD script that comes with CUE and modify it using the CUE Editor, with a time / date step, with the Call Redirect step pointing to your differing selected voicemail's depending on the Date / Time in the script.
03-04-2007 04:04 PM
Is there an option forward after working hours to a another extension. This extension would be his night voice mail?
Waiting for your feedback,
03-04-2007 04:19 PM
One thing to add this user has DID so that call want pass through the auto-attendant. It will directly hit his primary extension!
Appreciate any ideas,
03-05-2007 07:12 AM
Hi Mohamed,
I am thinking that maybe this CME feature would work for you;
call-forward night-service
To automatically forward calls to another number during night-service hours, use the call-forward night-service command in ephone-dn or ephone-dn-template configuration mode. To disable automatic call forwarding during night service, use the no form of this command.
call-forward night-service target-number
no call-forward night-service
Night-service hours are defined using the night-service date and night-service day commands.
An ephone-dn can have all four types of call forwarding defined at the same time: all-calls, no-answer, busy, and night-service. Each type of call forwarding can have a different forwarding destination defined in its target-number argument. If more than one type of call forwarding is in effect (is active) at one time, the precedence order for evaluating the different types is as follows:
1. call forward night-service
2. call forward all
3. call forward busy and call forward no answer
If you use an ephone-dn template to apply a command to an ephone-dn and you also use the same command in ephone-dn configuration mode for the same ephone-dn, the value that you set in ephone-dn configuration mode has priority.
Examples
The following example establishes night-service hours from 1 p.m. Saturday until 8 a.m. Monday. During that time, calls to extension 1000 (ephone-dn 1) are forwarded to extension 2346.
telephony-service
night-service day sat 13:00 12:00
night-service day sun 12:00 08:00
night-service code *1234
From this good doc;
Hope this helps!
Rob
03-05-2007 03:32 PM
That's exactly what I wanted!
04-03-2007 01:48 AM
I have been doing some testing with this command and it appears it only applies to the primary line like call-forward all does.
If a phone has several lines associated to it, you would have to go in via the CLI or gui and change each line to call-forward all, bit of a pain if the user does not want calls forwarded that are unanswered throughout the daytime but has lots of lines he/she wants to forward through to voicemail during the nightime.
