10-30-2008 07:04 AM - edited 03-15-2019 02:16 PM
Dear All,
New install Cisco2851, running CME4.2 version, ios is c2800nm-spservicesk9-mz.124-11.XW8.
As I run the CUE wizard, the administrator ID cannot be created, the CUE keeps reloading. the CUE is NM modile with harddisk installed.
The error message:
Enter administrator user ID:
(user ID): cmadmin
Failed creating cmadmin
Reason: Error in DB operation : SQL Query error; nested exception is:
org.postgresql.util.PSQLException: The backend has broken the c
Do you want to try with another user ID (y/n)?
INIT: Sending processes the TERM signal
Restarting system
The CUE is running 3.3.1 version, I had upgarded it to 3.3.2, the same result and error message.
I have upgraded the CME IOS to 124-11.XW9, the same result.
Do you have any idea? Is it hardware failure or software issue?
Thanks for any input in this case!!!
Michael.
10-30-2008 11:36 AM
Hi!
Does not sound like a HW issue. Try to reinstall the CUE as per:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/installation/guide/boothelp31.html
and see if this helps.
10-31-2008 07:20 AM
after download the CUE to 3.1.1, the issue is solved.
Michael.
