CUE error message on logon
When I logon to CUE it starts giving a long message before and in between sh run of config, I have pasted the output below. What is causing this and how can I stop it to dispaly. I have tried "term no mon", did not help and "sh debugging" doesn't show any debugs running.
hasrat
Generating configuration:
Apr 22 09:23:15 localhost cli:    INFO cli server output Command: calendar biz-schedule closed
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:361 : com.cisco.aesop.dbclient.Database : Got connection: 0, inUse: 1, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:362 : com.cisco.aesop.dbclient.Database : query: select one from business_hours where schedname = 'closed';
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:369 : com.cisco.aesop.dbclient.Database : Freed connection: 0, inUse: 0, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:373 : com.cisco.aesop.dbclient.Database : Got connection: 0, inUse: 1, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:374 : com.cisco.aesop.dbclient.Database : query: select two from business_hours where schedname = 'closed';
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:380 : com.cisco.aesop.dbclient.Database : Freed connection: 0, inUse: 0, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:385 : com.cisco.aesop.dbclient.Database : Got connection: 0, inUse: 1, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:386 : com.cisco.aesop.dbclient.Database : query: select three from business_hours where schedname = 'closed';
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:391 : com.cisco.aesop.dbclient.Database : Freed connection: 0, inUse: 0, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:397 : com.cisco.aesop.dbclient.Database : Got connection: 0, inUse: 1, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:399 : com.cisco.aesop.dbclient.Database : query: select four from business_hours where schedname = 'closed';
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:406 : com.cisco.aesop.dbclient.Database : Freed connection: 0, inUse: 0, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:410 : com.cisco.aesop.dbclient.Database : Got connection: 0, inUse: 1, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:413 : com.cisco.aesop.dbclient.Database : query: select five from business_hours where schedname = 'closed';
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:419 : com.cisco.aesop.dbclient.Database : Freed connection: 0, inUse: 0, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:423 : com.cisco.aesop.dbclient.Database : Got connection: 0, inUse: 1, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:425 : com.cisco.aesop.dbclient.Database : query: select six from business_hours where schedname = 'closed';
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:429 : com.cisco.aesop.dbclient.Database : Freed connection: 0, inUse: 0, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:436 : com.cisco.aesop.dbclient.Database : Got connection: 0, inUse: 1, active: 1
Apr 22 09:23:15 localhost superthread:    INFO superthread server output 22-Apr-10 09:23:15:437 : com.cisco.aesop.dbclient.Database : query: select seven from business_hours where schedname = 'closed';
1 ACCEPTED SOLUTION
Re: CUE error message on logon
Hi Hasrat,
Thanks for the output. Please go ahead and disable the console logging as follows:
se-10-104-149-150# sh logg
info:     on
warning:  on
errors:   on
fatal:    on
Filter Info:
MODULE           ENTITY           ACTIVITY        FILTER
No filter active
se-10-104-149-150#
se-10-104-149-150# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
se-10-104-149-150(config)# no log console info
se-10-104-149-150(config)# no log console warning
se-10-104-149-150(config)# no log console errors
se-10-104-149-150(config)# no log console fatal
se-10-104-149-150# show logg
info:     off
warning:  off
errors:   off
fatal:    off
Filter Info:
No filter active
se-10-104-149-150#
Do let me know if the messages stop after the above changes.
Harmit.
-- Regards, Harmit.
Hi Hasrat,
Not sure if this one has already been addressed..
Can you send me the following info:
++     Is this an AIM-CUE or an NM-CUE / NME-CUE?
++     Version of CUE?
++     output of "show logging" from the CUE
These appear to be cosmetic messages which are simply talking about connections to the DB. Once you send me the above info, I will be able to confirm and determine which logging is enabled that is causing these to show up.
Harmit.
-- Regards, Harmit.
Hi Harmit,
Thank you for the response, please see the information:
1- AIM-CUE
2 - CUE# sh software ver
Installed Packages:
- Installer  2.2.1
- Thirdparty  2.3.2
- Bootloader (Primary)  2.1.2
- Infrastructure  2.3.4
- Global  2.3.4
- Auto Attendant  2.3.0
- Voice Mail  2.3.2
- Bootloader (Secondary)  2.1.2
- Core  2.3.4
- GPL Infrastructure  2.3.0
Installed Languages:
- English language pack  2.3.0
3 - I have attached log file.
thanks again,
hasrat
Hi Hasrat,
Could you please provide the "show logging" output as requested earlier? Here is a sample output:
info:     off
warning:  off
errors:   off
fatal:    off
Filter Info:
No filter active
Thanks!
Harmit.
-- Regards, Harmit.
Seems like your CUE is stuck in a loop.
From your CME you can try to reset the CUE module.
Command: service-module   service-Engine reset
hth
It's not stuck in a loop based on the messages flooding the console of the CUE. Those are all informational messages (cosmetic) because someone has enabled them. Once we get the show logging output, I will be able to confirm the same.
Harmit.
-- Regards, Harmit.
Hi Harmit,
I apologize, there was nothing in it so I didn't send, please see it below:
CUE# sh logging
info:     on
warning:  on
errors:   on
fatal:    on
Monitored event  Info:
No monitored events active
Server Info:
Log server address:
CUE#
thanks
hasrat
Hi Hasrat,
info:     on
warning:  on
errors:   on
fatal:    on
Filter Info:
No filter active
se-10-104-149-150#
info:     off
warning:  off
errors:   off
fatal:    off
Filter Info:
No filter active
se-10-104-149-150#
Harmit.
-- Regards, Harmit.
Hi Hasrat,
Any luck on the above? If this helps, please rate this chain. Thanks.
Harmit.
-- Regards, Harmit.
Hi Harmit,
it fixed the issue, thank you for your help.
hasrat
363
