CUE failure/ fast busy
I have a CUE / CME integration.  When calling voicemail or auto attendant, a fast busy is experienced.  I did a some debugging and see that the call is hitting the proper dial peer, but when doing a debug ccsip I get:
"DisconnectCause 2F  , DisconnectText no resource"
I restarted the service module and the CME router.  This was a working configuration, and no changes were made.  Any suggestions?
Re: CUE failure/ fast busy
Can you session into CUE?  Ping? Make sure CUE hasn't crashed, or is unreachable.
Other than that, can you grab the following debugs:
debug ccsip mess
debug voip ccapi inout
Also, what do your VM and AA dial-peers look like?
I can session into the CUE, and ping etc.
Here are the debugs.  Thanks for your assistance.
621
