08-20-2014 09:02 AM - edited 03-16-2019 11:48 PM
I am facing a weird issue and wondering if someone have seen this before...
Plateforme is 2801 with CME 8.6, IOS 15.1 and CUE 7.4. I believe the version of CUE is compatible and should work with CME 8.6.
What's happening is I get an immediate fast busy when hitting the VM button on a phone.
The dial-peer is below for the VM pilot number:
dial-peer voice 7000 voip
destination-pattern 7000
session protocol sipv2
session target ipv4:10.1.150.2
dtmf-relay sip-notify
codec g711ulaw
Debug voip ccapi inout shows disconnection error code 38 - Network out of order
Not output from debug ccsip messages
Debug ccsip all shows CME creating a sip connection to the CUE module but it immediatly fails:
*Aug 17 15:07:40.983 CST: //6/FA0D0B74800E/SIP/State/sipSPIChangeState: 0x6A5BAEC0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
*Aug 17 15:07:40.983 CST: //6/FA0D0B74800E/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x6A5BAEC0
State of The Call : STATE_DEAD
TCP Sockets Used : YES
Calling Number : 4444
Called Number : 7000
Source IP Address (Sig ): 3.3.3.3
Destn SIP Req Addr:Port : 10.1.150.2:5060
Destn SIP Resp Addr:Port : 10.1.150.2:5060
Destination Name : 10.1.150.2
Tthe CUE module is up, licenses are installed and doesn't show any errors. Except dealing with a defective CUE module not sure why it is not accepting incoming SIP connections.
I would appreciate any inputs.
08-20-2014 09:54 AM
Can you post up your configs?
08-20-2014 11:07 AM
08-20-2014 10:12 PM
Hello Amine
Can you do a reload for CUE module ?.Also share the output of "debusg ccsip messages" .
please rate all useful information
08-22-2014 06:16 AM
I reloaded the CUE multiple times. No output when doing debusg ccsip messages.
I removed dial-peer 102 but no change. Debug voip dialpeer inout shows 7000 being matched.
Also no change after setting
ccn subsystem sip
default gateway address
default gateway port
All I can see is CUE not accepting a SIP connection and CCAPI inout debug shows Disconnection code 38 - Network out of order.
08-22-2014 08:38 AM
Amine
1- The problem happen internal when users press VM . Can you try to also dial from the phone VM.
2-Can u do upgrade for your CUE ?. Maybe this will solve your issue . I think no issues on your configuration.
Please rate all useful information
08-25-2014 05:51 AM
I finally found what was causing this issue. My config had this:
sip bind control source-interface Loopback0 bind media source-interface Loopback0 session transport tcp <<<<<<<<<<<<<
Looks like CUE doesn't like TCP as a transport protocol for SIP or the default is UDP. As soon as I removed the command from the config, CUE started accepting calls. Another workaround would be to set the transport protocol for SIP to UDP at the Dial-peer.
Glad I can put this to bed now!
08-21-2014 02:00 AM
Try removing this peer, or setting preference to 9 temporarily.
dial-peer voice 102 voip destination-pattern 1... session target ras
Default preference is 0 so this is probably taking the call rather than your peer 7000.
Aaron
08-20-2014 11:33 AM
Can you ping the CUE module sourcing from Loopback0?
ping 10.1.150.2 source loop0
08-20-2014 11:46 AM
Yep, connectivity works.
#ping 10.1.150.2 source loop0
Sending 5, 100-byte ICMP Echos to 10.1.150.2, timeout is 2 seconds:
Packet sent with a source address of 3.3.3.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4
I was also able to run the initialization Wizard successfully so I know CUE can talk to CME.
08-20-2014 02:09 PM
Might be worth reloading the module.
You can also try setting the sip subsystem to default config:
ccn subsystem sip
