CUE GUI admin page not accessible
I am not able to access cue gui.
I've already configured it with appropiat settings.
i also tried this:
1. In CUE config mode - "crypto key generate rsa label gui modulus 1024"
2. reload
4. In CUE config mode - "web session security keyLabel gui"
3. enable TLS 1.0 in IE and Firefox
4. In browser address bar enter:  https:// <cue ip> OR http://<cue ip>:443
didnt work
I'm using IE version 10
I configured CUE  wit ip address  it's reachable from all other sites.
But its not  accessible from my local machine.
did i forgot something?
1 ACCEPTED SOLUTION
Add route as below
route add 10.10.115.2 mask 255.255.255.0 -p.
And then try to ping
Regards, Nishant Savalia
Make sure you have the following:
ip http server
no ip http secure-server
ip http path flash:/gui
in the telephony-service
web admin system name ....
dn-webedit
is it neccasry that i have to configure cme first before enabling cue gui.
I didnt knew that cue had to do something with cme.
I thougt it was independend
From where you are trying to access youu CUE web page?
Are you able to ping that CUE IP address from the same device (from your PC / laptop) from where you are trying to access web page?
If you are not able to ping then add persistent route in your cmd prompt and try to access.
I see the problem i am not able to ping from my local laptop machine.
based on my site c router cue configuration
interface Service-Engine0/0
ip unnumbered Loopback1
service-module ip address 10.10.115.2 255.255.255.0
service-module ip default-gateway 10.10.115.1
i added this route in cmd.
route add 10.10.115.2 mask 255.255.255.0 10.10.115.1 -p
will this help because still not reachable
time out while pinging
Add route as below
Still no success, i will show you my routeprint
IPv4 routetabel
Actieve routes:
Netwerkadres             Netmasker          Gateway        Interface Metric
      10.10.210.0    255.255.255.0         On-link      10.10.210.15    281
     10.10.210.15  255.255.255.255         On-link      10.10.210.15    281
    10.10.210.255  255.255.255.255         On-link      10.10.210.15    281
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
     192.168.50.0    255.255.255.0         On-link    192.168.50.103    281
   192.168.50.103  255.255.255.255         On-link    192.168.50.103    281
   192.168.50.255  255.255.255.255         On-link    192.168.50.103    281
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link      10.10.210.15    281
        224.0.0.0        240.0.0.0         On-link    192.168.50.103    281
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link      10.10.210.15    281
  255.255.255.255  255.255.255.255         On-link    192.168.50.103    281
Permanente routes:
  Netwerkadres             Netmask  Gateway-adres    Metric
      10.10.115.2    255.255.255.0     10.10.210.15       1
pfff i am lost
Do you have UCCX installed?
If yes then you can open CUE from uccx.
You are not able to open from your latptop is just because of recheability problem. Try to add route and verify the same. It should work.
Re: CUE GUI admin page not accessible
Hi nishant,
It worked!
Your the men....
i disabled my LAN connection, re-enabled it.
Now it works fine i can ping  and reach my CUE GUI
awesome!
Thank you very much!
Great!!!
461
