CUE Initialization Wizard Cannot Login
I have done this before, so I'm not sure what the problem is this time.  I've been working on this CME/CUE router all day.  It's Sunday and I have a headache.
When I try to run the CUE Initialization Wizard it says "Login to CUCME as an administrator failed.  Check your CUCME configuration."
CME v. 10, CUE v. 8.6.6, 2921 ISR.
I am using the same password I use to log into the CME system.  The IP address of the CME system is correct.  I do not the "access-class" in the ip http area.  What is stopping me from logging in?
Thanks.
Hello
Any changes performed and can you please check CME gui file is present.
Can you please re-try adding following command
under telephony
1) telephony-service
    web admin system name admin secret 5
2) ip http authentication local
3) file privilege 0
Let me know if this works
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Thanks for replying Nadeem.  This did not work.
353
