08-31-2014 03:53 AM - edited 03-16-2019 11:58 PM
Dears,
I am having some issue with connectivity wit ISM , i am not able to ping the ISM module from router
08-31-2014 04:51 AM
IP configuration for ISM seems to be fine, did you apply 'no shutdown' under ism interface ?
And are you able to see ism module in 'show inventory' ?
Suresh
08-31-2014 04:53 AM
no shutdown applied
and show inventory shows the ISM module
08-31-2014 08:14 AM
Then it should work, hope some1 else can share their views. did you get a chance to reload the router ?
Suresh
09-04-2014 01:20 AM
i am able to access cue
but my voice mail and autoattend not working
