11-05-2009 01:54 AM - edited 03-15-2019 08:21 PM
I have a quick question about installing a new language for Voicemail.
I would like to know if my Cisco 3825 Router needs to be rebooted after I install the new language? I know the NME-CUE Module will probably be rebooted, but that won't affect the router right in the way that the users will still be able to make calls.
Also, I have the following file:
cue-vm-nl_NL-langpack.nme.3.1.2.prt1
Notice it's a .prt1 file. In the documents I've read, I saw a .pkg file. Is it still possible to install the language with the .prt1 file?
Thanks in advance,
Grant
Solved! Go to Solution.
11-05-2009 02:11 AM
Router needs no reload.
You should have already installed the "language pack" .pkg that is needed to install the individual .prt1 files.
11-05-2009 02:11 AM
11-05-2009 02:16 AM
Thank you p.bevilacqua.
NME-CUE Module supports up to 5 languages. I already had 5, but I deleted one, so I have 1 more slot for NL.
What do you recommend me to do? Install the new language during office hours or after? The logical one would be after, but if it's safe I could just do it during office hours, since my FTP server doens't work that well and I could get some help from my colleague with that.
11-05-2009 02:22 AM
All depends if your user are Ok with a brief outage during office hours.
I use a free FTP server on my laptop to upgrade anything, and it works very well.
11-05-2009 02:27 AM
Do you mean an outage of the Voicemail? Since the router doesn't need to be reloaded, the users can still place calls and receive calls.
None of the users use Voicemail yet. I'm planning on giving some users Voicemail after I install the new language. That's my final step I have to complete.
The NME-CUE Module isn't being used for anything yet.
I also use a free one, but I got some issues with going into Passive mode.
11-05-2009 02:30 AM
Since you gave no service yet, you may want to upgrade to 7.x to avoid doing that in the future. It takes less than one hour.
I use a FTPd by Pablo software and it works well.
11-05-2009 02:39 AM
Sorry, but is it safe to install? Because I can't make up from your reply if it's safe or not. Regarding the outage
We do have upgrading to 7.x planned in the future.
But what consequences will that have? Will I have to reconfigure everything or does the config remain?
11-05-2009 02:48 AM
As mentioned before, router needs no reload.
I've found that upgrade installs do retain config and prompts, but it's always wise to do a backup before.
11-05-2009 02:51 AM
Alright. Thank you very much for your help.
11-05-2009 08:56 AM
I got a problem
CM-CUE> software install add cue-vm-nl_NL-langpack.nme.3.1.2.prt1
WARNING:: This command will install the necessary software to
WARNING:: complete an add-on install. It is recommended that a backup be done
WARNING:: before installing software.
WARNING:: The system will briefly be brought to an offline state
WARNING:: This will terminate any active call and prevent new calls
WARNING:: from being processed.
Would you like to continue? [n] y
Downloading ftp cue-vm-nl_NL-langpack.nme.3.1.2.prt1
Bytes downloaded : 31284081
Validating package signature ... done
ERROR: Invalid package. Please verify if this is a valid package file.
As I mentioned before, it is a .prt1 file. How do I install this?
I got it from:
http://www.cisco.com/cgi-bin/tablebuild.pl/cue-312-nme
Do I have to do something else first?
11-05-2009 09:13 AM
As mentioned above, choose to install/upgrade the language pack .pkg file.
Then, choose languages from the menu.
11-05-2009 09:25 AM
Sorry. I missed that part for some reason.
I'm still not able to do it.
Could you please explain it to me in steps? Because I'm a newbie at this.
11-05-2009 10:12 AM
Nevermind.
Installed :D.
I was using the wrong version. I have 3.1.1.0. I was trying to install 3.1.2. Downloaded the 3.1.1. Installed it and it automatically picked the .prt1 file.
It's clear for me now how this works.
Thanks for everything :D
11-05-2009 10:52 AM
Basically you need to specify cue-vm-langpack.nme.3.1.2.pkg and you will be given the language choices in a menu.
