Silver
CUE Licence Type Conversion from CM to CME
I am deploying a CUE module which appears to have come from the factory set-up with CM licence pre-installed. Is conversion to CME possible?
I have read some other posts which state it cannot, nonetheless I have taken the opportunity to ask anyway just to make sure as there is constant change. And this:
<http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_2/installation/guide_/upglic32.html>
License Types
If your system is already configured, you cannot change the license type from Cisco Unified Communications Manager to Cisco Unified Communications Manager Express
or vice versa. To change your license type, you must first reinstall Cisco Unity Express and then change your license type before you configure your system in any way.
thanks in advance
Ajaz
1 REPLY
Re: CUE Licence Type Conversion from CM to CME
yes it's possible
what that means is that if you're already using CUE integrated with CCM then you need to reinstall (meaning it has already been configured). if it has not been configured then just change the license.
java
if this helps, please rate
java
www.cisco.com/go/pdi
168
