CUE License with CUCM 9.1
nithin louis
We have an IP telephony setup running on CME 9.x and with CUE 7.X.We are planning to upgrdae the CME to CUCM 9.1 and will retain the CUE as well.
What all the pre requisite have to taken for retain the CUE ?. Can use the same License for CUE?
Nithin Louis.
5 Replies 5
yahsiel2004
Level 7
Level 7
You have to change the license type from CME to CUCM. You should be able to transfer the licenses, but you have to reach out to the Cisco licensing team.
Yosh
HTH Regards, Yosh
Kevin Monteiro
Level 7
Level 7
Hi Nithin,
You would be able to migerate on the existing license for the CUE, but if you need to purchase more license for voicemail box for example. You will need to buy them from the Cisco Licensing team.
Here is the licensing link for your referece:
https://tools.cisco.com/SWIFT/LicensingUI/Quickstart
Kindly rate the post accordingly.
Kevin
Rob Huffman
Hi Nithin,
A couple of extra notes to add to the great info from Yosh & Kevin (+5)
You will need to upgrade CUE to be compatible with CUCM 9.1 as
show below;
Table 2: Cisco Unity Express: Unified CM Versions
Cisco Unity Express Versions
2.0.x2.1.x2.2.x2.3.12.3.33.0.x3.1.13.1.23.2.13.2.27.0.x7.1.x7.2, 8.07.3, 8.57.4, 8.6.18.6.4
2.3.22.3.4
Cisco Unified Communications Manager Versions3.3(3), 3.3(4), 4.0(1),
4.0(2)
4.1(2),
4.1(3)
4.2(1),
4.2(3)
4.3(1), 4.3(2)
5.0(1), 5.0(2), 5.0(3),
5.0(4)
5.1(1), 5.1(2),
5.1(3)
6.0(1)
6.1
7.x
8.0
8.5
8.6
9.0
NOTE:  CUCM version 5.1(1) does not interoperate with CUE version 3.2.x. Before  version 5.0, Cisco Unified Communications Manager was known as Cisco  Unified CallManager.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.html
In addition, if you are currently @ CUE 7.0 you will need to move to CSL licenses;
Migrating to CSL Licenses
When you upgrade to version 7.1 or later, you must replace your  pre-CSL  licenses with CSL licenses. You are required to migrate your  licenses  for mailbox features and port features. If you purchased the  optional  IVR features, you must also migrate your licenses for the IVR  features.  The migration procedure for each of these types of licenses  are  described in a separate section below.
Note If you are upgrading to the same of licensed features as before, the CSL licenses are free.
When   you obtain licenses for features for Cisco Unity Express 7.1 or later,   the licenses are available only in the increments shown below. The   following types of licenses are available:
Mailboxes (available only in increments of five)
Ports (available only in increments of two)
IVR (available only in increments of two)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/Licensing/Using_CSL.html
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
Great info Rob (+5)
Yosh
HTH Regards, Yosh
Hey Yosh,
Thanks buddy
Cheers!
Rob
- OneRepublic
