Community Member
CUE Licensing..
Hello Everyone,
I am having problem with CUE licensing. I cannot creat voice mailbox in cue. Is that because of License?
If so, what should I do next. Please advise.
CUE# sh license status application
voicemail disabled, no activated mailbox license available
ivr disabled, no activated ivr session license available
CUE# sh license status application voicemail
CUE# sh license in-use
StoreIndex:  0  Feature: VMIVR-PORT                        Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: 6 /6
        License Priority: Medium
Andrew
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CUE Licensing..
Hi Andrew,
To get you started running on the demo license use;
service-module# no license activate ivr sessions
Then you will be able to use the VM feature.
As for the "Permanent" licenses you will need to
work with;
licensing@cisco.com
To secure the full licenses.
Cheers!
Rob
Community Member
Re: CUE Licensing..
Hi Andrew,
You can buy CSL licences for the following types of features:
Mailboxes Ports IVR TimeCardView
Currenly you have only port license.You have to purchase mailbox license also to activate mailbox also.CUE comes with 8week demo license for all features.You can use this if ur license delivery takes time.
https://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/Licensing/Using_CSL.html
he above URL will help you.
Bijin
Community Member
Re: CUE Licensing..
Hi Bijin,
How can I try that 8 weeks demo license? If I wan to purchase license, what kind of license should I get?
Reference to http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_1/install/over.html#wp1084665,
I found one License code which is as follow. Is it the correct one that I need to get?
SCUE-LIC-25CME=           Unity Express License 25 Voice Mailbox-Auto Attendant-CCME
All your advice will be much appreciated.
Andrew
Hall of Fame Super Gold
Re: CUE Licensing..
Why the rating of "3" to a 100% correct and helpful reply above ?
Please be more considerate when rating posts in this forum.
I have rated for what it's worth, a °5°.
Community Member
Re: CUE Licensing..
Noted.
Thanks for your remind Mr.Bevilacqua.
Community Member
Re: CUE Licensing..
You can purchase CUE mailbox license
FL-CUE-MBX-5 Unity Express License - 5 Mailbox - CUCM and CUCME
Inorder to activate he demo
1.
show license evaluation
2.
license activate voicemail mailboxes
# of mailboxes to be activated
3.
license activate ports
# of ports to be activated
4.
# of ivr sessions to be activated
5.
license activate timecardview
# of TimeCardView users to be activated
6.
reload
7.
show license in-use
Use this command to display which evaluation licenses are on your system, as shown in the following output:
service-module#
StoreIndex: 0 Feature: VMIVR-VM-MBX Version: 1.0
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
License Count: 600 / 0
License Priority: None
StoreIndex: 1 Feature: VMIVR-PORT Version: 1.0
License Count: 60 / 0
StoreIndex: 2 Feature: VMIVR-IVR-SESS Version: 1.0
DETAILED STEPS
Step 1
Re: CUE Licensing..
Hi Neil,
It looks like the 6 available Ports have been dedicated to the IVR sessions/service
which would leave 0 for standard VM access. I also don't see any permanent VMbox
licenses loaded
From Amit,
https://www.myciscocommunity.com/docs/DOC-17720
        License Count: 6 /6
Cheers!
Rob
Community Member
Re: CUE Licensing..
Thank you Guys,
I activated the demo and here's my current sh license in-use.
         License Count: 6 /6
             Evaluation period left:  8 weeks  3 days
             Expiry date: Fri Oct 22 22:25:07 2010
         License Count: 600 /30
         License Priority: Low
         License Count: 60 /6
but I still cannot use voice mail function. Following is the license status.
voicemail disabled, ivr session quantity (6) is equal to or exceeds available ports (6)
ivr enabled: 6 sessions
According to Mr.Amit Document, I need to install cue license using ftp server. Am I right?
Where can I download pkg file for my module? | My cue version is AIM2-CUE-K9 |
Do I need to have valid SLA with Cisco?
Really appreciate your kind support.
Cheers,
Andrew
Re: CUE Licensing..
Depending on a variety of factors, you may be entitled to migration licenses.
These may be obtained immediately online at: https://tools.cisco.com/SWIFT/Licensing/LicenseAdminServlet/displayUpgradeableProducts using the product S/N.
Re: CUE Licensing..
Hi Andrew,
work with;
licensing@cisco.com
Cheers!
Rob
Community Member
Re: CUE Licensing..
Thank you Guys!
I can successfully installed demo license and here's my license status.
voicemail enabled: 6 ports, 6 sessions, 30 mailboxes
ivr disabled, ivr session activation count has been set to zero
I'll test with demo license and buy permanent one later on.
Appreciate your kind support.
Cheer!
Andrew
3050
