CUE & MWI issues
Hi All,
I am having an issue with CUE and MWI not working. I have it setup but it's not working and I'm getting some odd errors in the debugs. It is NM-CUE 2.3.2 running on a 2811 with IOS 12.4.9T1. Config items:
dial-peer voice 100 voip
incoming called-number 1109[8,9].....
codec g711ulaw
no vad
ephone-dn 10
number 11099.....
mwi on
ephone-dn 11
number 11098.....
mwi off
msageunity01# sh ccn app | page
Description: ciscomwiapplication
Script: setmwi.aef
ID number: 0
Enabled: yes
Maximum number of sessions: 8
CallControlGroupID: 0
strMWI_OFF_DN: 11098
strMWI_ON_DN: 11099
Attached is what I think is a relevant section of the CUE MWI trace logs.
Two things don't seem to be right.
1) SIP/2.0 404 Not Found
2) The Java exceptions can't be good
Any ideas?
Stephen
Re: CUE & MWI issues
Here are the router's SIP Call Message tracing and SIP media debugs. Also in these is the 404 error.
Dec 5 20:18:23: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:11099204@10.7.95.1:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.7.96.50:5060;branch=z9hG4bKBXytRG0TgwC0VVtZIS9i5w~~934
Max-Forwards: 70
To: <11099204>
Call-ID: 1165349903161547@10.7.96.50
CSeq: 1 INVITE
Content-Length: 174
Contact: <621>
Content-Type: application/sdp
Call-Info: <10.7.96.50:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Allow-Events: telephone-event
v=0
o=CiscoSystemsSIP-Workflow-App-UserAgent 2876 2876 IN IP4 10.7.96.50
s=SIP Call
c=IN IP4 10.7.96.50
t=0 0
m=audio 16902 RTP/AVP 0
a=rtpmap:0 pcmu/8000
a=ptime:20
Dec 5 20:18:23: //148/97483FE08164/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
Dec 5 20:18:23: //148/97483FE08164/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g711ulaw, bytes :160
Preferred DTMF relay : sip-notify
Preferred NTE payload : 101
Early Media : No
Delayed Media : No
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
Dec 5 20:18:23: //148/97483FE08164/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.7.96.1
Stream type : voice-only
Media line : 1
State : STREAM_ADDING (2)
Callid : -1
Negotiated Codec : g711ulaw, bytes :160
Negotiated DTMF relay : sip-notify
Negotiated NTE payload : 0
Negotiated CN payload : 0
Media Srce Addr/Port : 10.7.96.1:0
Media Dest Addr/Port : 10.7.96.50:16902
Dec 5 20:18:23: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 18288 for stream 1
Sent:
SIP/2.0 100 Trying
To: <11099204>;tag=695CF0-829
Date: Tue, 05 Dec 2006 20:18:23 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Content-Length: 0
Sent:
CSeq: 1 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Received:
ACK sip:11099204@10.7.95.1:5060;user=phone SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
I'd need to see the CUE (& CME) configs, but my guess is that you need to configure the sip subsystem gateway to 10.7.96.1 in CUE.
E.g. config t
ccn subsystem sip
gateway 10.7.96.1
end
end
wr
reload
Then after it comes up (I'm pretty sure a reload is needed.. might want to try it first before doing that), test it again.
I wish it were that simple. That part already setup. Is there something in CME I should be looking for?
msageunity01# sh ccn subsystem sip
SIP Gateway: 10.7.95.1
SIP Port Number: 5060
DTMF Relay: sip-notify,sub-notify
MWI Notification: outcall
Transfer Mode: bye-also
SIP RFC Compliance: Pre-RFC3261
The SIP trace makes it look like your extension is three digits long. However, your MWI numbers are trailed by five dots. Could you please send a "show run" including all of your dial peers?
306
