CUE MWI
Dear NetPro gurus,
I tried everything but couldn't get my MWI to work on CUE & CME integration.
CME itself: 10.69.254.30
CUE ISM card:  10.69.254.28
There are 4 unread Voicemail on the IP Phone, but MWI just won't work... (users can listen to message, just MWI has no light)
interface ISM0/0
description CUE running on SRE Module
ip vrf forwarding voip
ip address 10.69.254.30 255.255.255.248
service-module ip address 10.69.254.28 255.255.255.248
!Application: CUE Running on ISM
service-module ip default-gateway 10.69.254.30
end
On CUE Module
se-10-69-45-253# ping 10.69.254.30
PING 10.69.254.30 (10.69.254.30) 56(84) bytes of data.
64 bytes from 10.69.254.30: icmp_seq=1 ttl=255 time=0.161 ms
64 bytes from 10.69.254.30: icmp_seq=2 ttl=255 time=0.109 ms
64 bytes from 10.69.254.30: icmp_seq=3 ttl=255 time=0.108 ms
64 bytes from 10.69.254.30: icmp_seq=4 ttl=255 time=0.108 ms
64 bytes from 10.69.254.30: icmp_seq=5 ttl=255 time=0.109 ms
--- 10.69.254.30 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.108/0.119/0.161/0.021 ms, ipg/ewma 0.164/0.139 ms
se-10-69-45-253# ping 10.69.254.28
PING 10.69.254.28 (10.69.254.28) 56(84) bytes of data.
64 bytes from 10.69.254.28: icmp_seq=1 ttl=64 time=0.058 ms
64 bytes from 10.69.254.28: icmp_seq=2 ttl=64 time=0.012 ms
64 bytes from 10.69.254.28: icmp_seq=3 ttl=64 time=0.007 ms
64 bytes from 10.69.254.28: icmp_seq=4 ttl=64 time=0.007 ms
64 bytes from 10.69.254.28: icmp_seq=5 ttl=64 time=0.006 ms
--- 10.69.254.28 ping statistics ---
rtt min/avg/max/mdev = 0.006/0.018/0.058/0.020 ms, ipg/ewma 0.054/0.037 ms
se-10-69-45-253#
se-10-69-45-253# show ccn application
Description:                            sip
Application type:                       aa
Script:                                 noscript
ID number:                              6
Enabled:                                yes
Maximum number of sessions:             8
Description:                            promptmgmt
Script:                                 promptmgmt.aef
ID number:                              4
Enabled:                                yes
Maximum number of sessions:             1
appManagementScript:
Description:                            autoattendant
Script:                                 aa.aef
ID number:                              1
Enabled:                                yes
Maximum number of sessions:             10
allowExternalTransfers:                 false
busClosedPrompt:                        AABusinessClosed.wav
businessSchedule:                       systemschedule
busOpenPrompt:                          AABusinessOpen.wav
dialByExtnAnytime:                      false
dialByExtnAnytimeInputLength:           4
dialByFirstName:                        false
disconnectAfterMenu:                    false
holidayPrompt:                          AAHolidayPrompt.wav
MaxRetry:                               3
operExtn:
welcomePrompt:                          AAWelcome.wav
Description:                            voicemail
Script:                                 voicebrowser.aef
ID number:                              2
Enabled:                                yes
logoutUri:                              http://localhost/voicemail/vxmlscripts/mbxLogout.jsp
uri:                                    http://localhost/voicemail/vxmlscripts/login.vxml
Description:                            msgnotification
Script:                                 msgnotify.aef
ID number:                              5
Enabled:                                yes
DelayBeforeSendDTMF:                    1
Description:                            ciscomwiapplication
Script:                                 setmwi.aef
ID number:                              3
Enabled:                                yes
CallControlGroupID:                     0
strMWI_OFF_DN:                          8280
strMWI_ON_DN:                           8281
se-10-69-45-253# sh ccn subsystem sip
SIP Gateway:                            10.69.254.30
SIP Port Number:                        5060
DTMF Relay:                             sip-notify,sub-notify
MWI Notification:                       unsolicited,sub-notify
MWI Envelope Info:                      enabled
Transfer Mode:                          bye-also
SIP RFC Compliance:                     Pre-RFC3261
se-10-69-45-253#
I have also attached CME & CUE configs.
I have spent a long time on this but couldn't get it to work, would apprecited if anyone can shed some light on this.
Cheers,
Hunt
Everyone's tags (2)
VIP Super Bronze
Re: CUE MWI
NB: Please ignore my earlier post:
Hi Hunt,
can you enable the ff: trace
trace ccn stacksip dbug
trace voicemail mwi all
You can then do a MWI refresh or do a new test call leave a message..after you are done
do a 'show trace buffer tail'
attach in a zip file and send the result here..
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Re: CUE MWI
You can also try and use this ip address as your IP source-address in CME :10.69.254.30 instead of the one you have now..
300
