CUE not comming online
hi,
I bought the following equipment and inserted the ism module in 2911 router. i first reset it and when try to session into it.
ISM-SRE-300-K9=Internal Services Module (ISM) with Services Ready Engine1
SCUE-ISM-8.6-K9Cisco Unity Express Release 8.61
FL-CUE-MBX-5Unity Express License - 5 Mailbox - CUCM and CUCME7
its not allowing me and changing state from SERVICE_MODULE_STATE_WREG to SERVICE_MODULE_STATE_ERRQ, to SERVICE_MODULE_STATE_ERRQ to SERVICE_MODULE_STATE_SHDN, to SERVICE_MODULE_STATE_SHDN to SERVICE_MODULE_STATE_FAIL. following are the messages.
Jul 21 13:51:06.315: %SRE_SM-6-STATE_CHANGE: ISM0/0 changing state from SERVICE_MODULE_STATE_WREG to SERVICE_MODULE_STATE_ERRQ
Jul 21 12:54:39.647: %SRE_SM-6-STATE_CHANGE: ISM0/0 changing state from SERVICE_MODULE_STATE_ERRQ to SERVICE_MODULE_STATE_SHDN
Jul 21 13:04:39.647: %SRE_SM-6-STATE_CHANGE: ISM0/0 changing state from SERVICE_MODULE_STATE_SHDN to SERVICE_MODULE_STATE_FAIL
I want to know whether i have to install cue software in it first? following is the configuration which i did.
int gig 0/0
ip address 10.10.22.11 255.255.255.0
no sh
interface ISM0/0
ip unnumbered GigabitEthernet0/0
service-module fail-open
service-module ip address 10.10.22.12 255.255.255.0
service-module ip default-gateway 10.10.22.11
end
ip route 10.10.22.12 255.255.255.255 ISM0/0
CME-CALL-AGENT#service-module iSM 0/0 status
Service Module is Cisco ISM0/0
Service Module supports session via TTY line 131
Service Module is trying to recover from error
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
No install/uninstall in progress
CME-CALL-AGENT#
[Resuming connection 1 to 10.10.22.11 ... ]
Initializing memory. Please wait...
Naray
Hall of Fame Super Silver
CUE comes pre-installed, have you tried resetting the module? What happens?  What happens when you try
service-module iSM 0/0 session
HTH,
Chris
after resetting. its going through following state
and when i session into the module. its denying the connection..is the module faulty? do i need to install cue and see?
Hall of Fame Super Gold
Do clear line vty 2 (or whatever right number) to make the connction.
Ans you need to install software because new modules come without.
Re: CUE not comming online
cant i session in the ise module and then install the application
or there has to be some application in ISE before i can session in. if yes then will the cue-installer.ise.8.6.1 file would be enough to session in??
Some CUE models, I think the ISM does, support installation from IOS CLI "service module x/y install url", try that before installing from session.
so as per you the problem is that cue software is not installed in ISE that is why i am receiving the errors. ?? ... i will try to install the software. yes i can use the command to install the software and then will try to session in.. but if the problem is still the same then can i safely assume that the module is faulty?
Don't make assumptions, install the software instead.
You will also need to request the port licenses included in the product to licensing@cisco.com
hi,
today i tried to install the cue 8.6.1 but got following result.
CME-CALL-AGENT#$url ftp://cisco:cisco@10.10.1.11/cue-installer.ise.8.6.pkg ?
  argument  Specify a quoted string argument for the script
  force     Ignore all warnings
  script    Select script to use for installation
Proceed with installation? [no]: yes
Jul 24 08:51:52.523: %SM_INSTALL-6-INST_RSRC_GET: Getting resource information from ISM0/0.
CME-CALL-AGENT#
Jul 24 08:53:52.531: %SM_INSTALL-3-INST_NORESP: ISM0/0 SW installation failed module not responding
Then connect via session and check what's going on.
CME-CALL-AGENT#
[Resuming connection 1 to 10.10.22.11..]
Keep session in one window.
Open another telnet, and from there do service-module reset.
If you see it booting, interrupt with ***, then followo installation using tftp and installer imager.
I tried those steps, but it
I tried those steps, but it is not  showing *** to change configuration. Not able to get into the session
D: VIC2-2FXO         , VID: V02 , SN: FOC11500RCK
NAME: "PVDM3 DSP DIMM with 16 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 16 Channels"
PID: PVDM3-16          , VID: V01 , SN: FOC16080Z4L
NAME: "Internal Services Module with Services Ready Engine on Slot 0", DESCR: "Internal Services Module with Services Ready Engine"
PID: ISM-SRE-300-K9    , VID: V02 , SN: FOC18010MFS
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
PID: PWR-2911-AC       , VID: V03 , SN: DCA1537R2RD
CUBE2911#serv
CUBE2911#service-module ism
CUBE2911#service-module ism 0/0 se
CUBE2911#service-module ism 0/0 session
Trying 172.16.11.1, 2131 ... Open
Memory initialization OK. Continue...
*Aug  4 12:42:10.027: %SRE_SM-6-STATE_CHANGE: ISM0/0 changing state from SERVICE_MODULE_STATE_FAIL to SERVICE_MODULE_STATE_ERRQ
User Access Verification
Username: admin
Password:
CUBE2911#
CUBE2911#
CUBE2911#ser
CUBE2911#service-module ism 0/0 res
CUBE2911#service-module ism 0/0 reset
Use reset only to recover from shutdown or failed state
Warning: May lose data on the the NVRAM, nonvolatile file system or unsaved configuration!
Do you want to reset?[confirm]
Trying to reload Service Module ISM0/0.
1764
