02-15-2014 02:38 PM - edited 03-16-2019 09:45 PM
I have a CME and CUE setup. When an outside caller calls, their DTMF inputs are not recognized by the CUE.
I am attaching Copies of both configs.
Solved! Go to Solution.
02-15-2014 03:27 PM
Do you have a transcoder configured? CUE only supports g711ulaw and you must set the dtmf-relay type to rtp-nte. Make sure your inbound dial-peer has the correct dmtf-relay and if using different dtmf-relay configure a transcoder.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/91535-cme-sip-trunking-config.html
Sent from Cisco Technical Support Android App
02-15-2014 03:27 PM
02-16-2014 09:52 AM
The transcoding worked great!!! I realized that I had the two prompts miss configured on the Auto Attenant. The Welcome must be a short blank, then the Business Open prompt should be the outgoing recording. A caller can not input digits while the Welcome prompt is playing.
Thanks for all your help.
02-15-2014 03:30 PM
Sorry I meant sip-notify not rtp-nte
02-16-2014 10:52 AM
Glad to hear that everything is working.
Yosh
