11-03-2010 02:59 AM - edited 03-16-2019 01:42 AM
Hi all
I have tried to have a dig around but am not getting clear information. Can someone inform what is the max number of licensed user mailboxes is for the CUE card and the motherboard module (which I understand will support less)??
I understand that this may be chasis specific also.
Solved! Go to Solution.
11-03-2010 04:11 AM
These numbers are clearly detailed in the software release notes, to which you should refer.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/prod_release_notes_list.html
Please note, there are various hardware avaialble for CUE, not jsut "card" and "motherboard". And the numbers are not chassis specific.
11-03-2010 05:52 AM
Hi Simon,
I thought you might find these tables helpful
License Support
Table 8. License Support for Version 7.0 and Earlier
Table 9. License Support for Version 7.1 and Later
Cheers!
Rob
11-03-2010 04:11 AM
11-04-2010 02:47 AM
Thanks for the reminder....sometimes we go blank...
11-03-2010 05:52 AM
Hi Simon,
License Support
Cheers!
Rob
11-04-2010 02:43 AM
Thanks Rob.....the information was spot on
