CUE Question
Can a CUE module support multiple CMEs? Like having one CME integrate via SIP with CUE, then have another CME integrate with that one via H.323 call forward and SIP MWI (similar to how you would support multiple CMEs with Unity).
Thanks.
1 ACCEPTED SOLUTION
Silver
Re: CUE Question
Hi, it isn't supported, you can see it at the CUE design guide "Unsupported Deployments":
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_implementation_design_guide_chapter09186a00804993bd.html
Hope this helps, if so pls rate post
1 REPLY
Silver
Re: CUE Question
103
