10-25-2010 12:02 PM - last edited on 03-25-2019 08:02 PM by ciscomoderator
I was doing some scripting for an AA and i wanted to route the calls based on the DNIS, however on the CUE script editor I couldn't actually debug the script and since my script wasn't properly working
i enabled some debugging on the CUE and realized that my script will never work because the DNIS is always null no matter what.
I have a PRI connected to a 2811 running CME.
this is the output of my debug
ContactApplicationTrigger[time=1287895074745,contact=SIPCallContact[id=
3749,type=Cisco SIP Call,implId=4D74CABD-DE5F11DF-8060C84A-F00DAF00@10.1.10.2,ac
tive=true,state=CALL_RECEIVED,inbound=true,handled=false,locale=en_US,aborting=f
alse,app=App[name=pub_safety_aa,type=Cisco Script Application,id=7,desc=pub_safe
ty_aa,enabled=true,max=6,valid=true,optional=[script=pub_safety_aa.aef,cfgVars=[
Lcom.cisco.wfapi.util.WFNameValuePair;@f3202f,privilegeType=1,last.modified=1287
636016736]],task=20000003217,session=Session[id=0x12a05fe93,parent=null,active=t
rue,state=SESSION_IN_USE,time=1287895074732],seqNum=0,time=1287895074728,cn=8004
,dn=null,cgn=5293053125,ani=null,dnis=null,clid=sip:5293053125@10.1.10.2,atype=D
IRECT,lrd=null,ocn=8004,odn=null,uui=null,aniii=null,ced=null,lrvmn=null,ocvmn=8
004,route=TR[num=8004],port=Port[type=Cisco SIP Channel,id=0,implId=16896,active
=true,state=IN_USE],aborting=false,transferring=false,disconnecting=false]]
An object of com.cisco.wfframework.engine.core.WFEngineWorkflowDebugTask
as you can see from the log, the DNIS parameter is always null
is there a setting that we need to change on CUE or perhaps CME or perhaps on the Dial-peer pointing to CUE ?
thanks
Solved! Go to Solution.
10-25-2010 12:08 PM
THe reason the DNIS is null is that it would only
contain the pilot number for CUE. Look for the redirecting number, that is t
he number that sent the call to CUE, which shoul
d ber the original called number/extension.
10-25-2010 12:08 PM
