Community Member
CUE script with no parameters
I've some trouble with a CUE 2.3.4
The system is running from several time and now I've to add a new scritp.
I've done the script with the CUE editor 2.3.4 and it's validated.
When I import into CUE and I press next to get the parameters windows, i get an empty window ( so i cannot configure the variables ) .
Any Idea ? The only strange issue is that, also if the system is working fine, i see all script as "possibly corrupted". This is a bug that shoud be solved in 2.3.1 ( !?!? ).
Any ideas ?
Luigi
Hall of Fame Super Gold
Re: CUE script with no parameters
Are the variables made parameters with the setting in property box ?
Community Member
Hi Paolo,
I've some news ( maight be news for me and not for You ). I upgraded CUE to 3.1.2 and, after the configuration and a reload of the router WITHOUT SHUTDOWN THE CUE, i went another time in "corrupted script".
Are the cue so "sensible" to reload without to shutdown ?
Luigi
Community Member
Now I made another test. Also shutting down the cue I'd the same issue.
1) installed a fresh cue sw
2) configured and tested
3) back to the router and shutdown the cue
4) reloaded the router
Now I get another time "script corrupted"
Any suggest ?
regards
Luigi
Hi, I never had problem reloading the router without CUE shutdown, but maybe I've been just lucky.
What matters is that you save the CUE configuration via CLI or web "control panel".
Community Member
Hi Paolo,
thanks for Your useful quick reply. I just opened a case: all was working fine but after the reload:
- custom script "disappeared"
- system script showed as "possibly corrupted"
The strange thing is that the system is still working fine BUT i cannot do any change in the script ( i cannot change prompt or parameters ). To be more clean, it seems i can change but .... with no result.
So, the custome script are not showed anymore ( via web ) but they are still somewere.
I will Keep You informed.
regards
Luigi
Bronze
Hi Luigi, yo need to define your variable and check the "parameter" checkbox in your new script created and you will be able to change the value.
Hope this help
David
Community Member
thanks for the reply but all the variables has the parameters flag set. It seems more like a bug, but i wanted just to check if it was happened just to me.
regards
Luigi
Community Member
Hi Luigi,
have you solved your problem ?
Marco Scaramelli
160
