CUE Transfer to any extension help
I need to set up a CUE script in where the caller can dial by extension at any time during the opening greeting. I've tried to configured but it drops the call as soon as I dial the first digit of the extension i want to reach. Can some shed some light. I've been using the Cisco scripts as a guide.
I have included the script.
CUE ver 2.3.4
Armando
Green
Re: CUE Transfer to any extension help
You will need to input the digits one by one and make the decision.
Play the Menu prompt.
then call Get Digit String
After that compare String with Menu Definitions:
Option1="1"
Option2="2"
Option3="3"
for example:
Multiple IFs
If (String == Option1) go to OPT1
If (String == Option2) go to OPT2
If (String == Option3) go to OPT3
Else
Use call redirect step and transfer the call to the selected extension.
Or Use Switch Function to avoid multiple IFs
Armando
118
